Air idle control valve issues help needed
Old Nov 24, 2014 | 01:04 PM
inmate's Avatar
Default Air idle control valve issues help needed
02 S type with 3.0 engine and automatic trans.
Getting misfires code and tells the issue is the "air idle control valve" yet when I call for parts, told its only sold as part of the throttle body assembly. The cost for that part is over $2 thousand dollars.
Has anyone here fixed this problem with out spending that kind of money? Find a used throttle body will cost $1100.
Any ideas or help would be appreciated.
Old Nov 24, 2014 | 02:43 PM
JagV8's Avatar
Ignore that for now. It's likely a coil or air leak. Which codes did you get?
Old Nov 24, 2014 | 03:45 PM
tony1963's Avatar
I agree. Buy new plugs and coil packs. Also replace the breather elbow while you are in there along with new upper and lower intake gaskets.
Then, clear all codes and start over.
Old Nov 24, 2014 | 05:01 PM
joycesjag's Avatar
Right on with post # 2 and #3. The 3.0 V6 is very documented here, before you drop the big bucks, let us help you through the diagnosis.
Old Nov 24, 2014 | 09:20 PM
Gus's Avatar
Gus
Yes please post the actual codes and not what you are told they mean.
BrentGardner
29
Dec 16, 2024 12:13 AM
Jimscriv
Nov 4, 2015 02:18 PM
97xj6lucy
Sep 3, 2015 07:44 AM
daro31
Aug 27, 2015 09:26 AM
divingmom
Aug 25, 2015 07:54 PM
