alarm light stays on kills battery and alternator
Old Oct 1, 2017 | 03:46 PM
dragon53's Avatar
Default alarm light stays on kills battery and alternator
2001 Jaguar S-type 4.0 V8
Old Oct 1, 2017 | 05:24 PM
JagV8's Avatar
May be symptom not cause.
Which light and exactly what do you mean by stays on?
Plausible causes include the light stalk and the ignition flap but you could hardly give much less information.
Old Oct 2, 2017 | 01:17 AM
dragon53's Avatar
the anti-thief light in the window that should flash when alarm is set. Also the battery light stays on and the traction control warning appears and car shuts off.
Old Oct 2, 2017 | 02:29 AM
JagV8's Avatar
Load test battery, test items I posted, check powers & grounds.
Old Oct 2, 2017 | 03:18 AM
stevep10's Avatar
Plug it in and get the codes. It will have thrown some for that lot.
Old Oct 2, 2017 | 03:39 AM
Datsports's Avatar
yes , but most likely a string of false one's too if it is a failing ALT or BAT.
start with the volts .
Old Oct 2, 2017 | 03:53 AM
JagV8's Avatar
If it's not the batt or alt (or connections for them), expect to spend a LOT of hours finding the fault.
Old Oct 2, 2017 | 03:59 AM
stevep10's Avatar
Quite possibly. With the battery light on permanently then that alone indicates a possible alternator problem, not charging the battery properly, easy enough to check with a multimeter.
The DSC warning coming on and the car shutting off could also be a symptom of a bad battery voltage, but I would think it would show bad starting ability/slower cranking before it showed up this lot.
Unless of course the OP is jump starting it off another car/battery and hasn't said yet?
Old Oct 2, 2017 | 05:35 AM
JagV8's Avatar
Terse posts tend not to help get solutions.
tmwsccsh
Aug 18, 2020 09:10 AM
binkleytom
Sep 2, 2019 12:06 AM
Gophat
Dec 11, 2017 04:49 PM
G. Repetti
Jul 26, 2017 08:56 PM
1 of 19
Jul 19, 2017 07:49 PM
