All cylinders Misfiring
Old Nov 21, 2017 | 02:40 PM
htretola's Avatar
Default All cylinders Misfiring
my car was running perfectly fine yesterday, went to go start it this morning, and it sounds horrible. Readings attached, any help would be greatly appreciated! Thank you!
Old Nov 21, 2017 | 06:49 PM
Welcome to the forum htretola,
If you add Model and Year details, you will get some help ......
Old Nov 21, 2017 | 07:58 PM
motorcarman's Avatar
I hate mystery cars................. I'm OUT
bob
Old Nov 22, 2017 | 02:24 AM
I've added the vehicle details from your Intro to your original post and moved your question from General Tech Help to S-Type forum. Members here with the same model will be able to help.
Old Nov 22, 2017 | 06:34 AM
kr98664's Avatar
Welcome to the forum. Looks like we have the same scanner. Xtool Bluetooth? I recognize those screenshots.
By chance was your car parked outside in the rain? First thing I'd check, considering multiple misfires suddenly appearing, is rainwater collecting in the spark plug wells. That will cause all sorts of havoc.
And more details like year and engine, please. My mindreading skills just aren't what they used to be. I see a misfire logged for cylinder #7, so I'm assuming (Danger! Danger!) you've got the V8. If you've got that fault on a V6, something is really wrong.
Old Nov 22, 2017 | 02:14 PM
stevep10's Avatar
I'm going to have a stab at this one, given you have a cylinder 8 listed there.
I'm basing this "guess", and that's what it is, a "guess", on the two codes PO345 and 346, your cam codes.
I reckon your chains have slipped a couple of teeth.
Old Nov 22, 2017 | 03:47 PM
JagV8's Avatar
In case that could be so DO NOT START THE ENGINE!!
DO NOT EVEN CRANK IT.
Old Nov 22, 2017 | 06:09 PM
kr98664's Avatar
What's the best way to diagnose a slipped timing chain on these engines?
Hoping the OP sticks around so we can help. My Spidey senses are saying otherwise, as often happens...
Old Nov 23, 2017 | 10:24 AM
JagV8's Avatar
Why is this thread "All ..."? I don't see misfires for cyl 1 or 7 for example.
You risk bad replies in case you're misleading.
Old Nov 23, 2017 | 11:10 AM
kr98664's Avatar
Well, that's strange. Did the pictures get replaced? In my earlier post (#5 above), I mentioned seeing a code set for #7...
Old Nov 23, 2017 | 11:50 AM
JagV8's Avatar
Odd. Dunno
Old Nov 24, 2017 | 04:14 AM
stevep10's Avatar
As I said in my post, it's only a guess; but, based on my own experience with my V8 (Bought myself a new toy thread) I got the cam code just by having the exhaust cams 1 tooth out of alignment.
I know you can get away with the cams skipping 1 tooth and not have the valves contact the pistons, and the car will still run, but any more than that you're in trouble.
As the OP said, it was running the previous day with no issues. Tried to start in the morning and SOUNDS HORRIBLE, then all these codes.
With the cams slipped more than 2 teeth out, the sensors will detect everything not sending signals at the right time. Plus with a slipped chain, it may well start but will sound like a devil juice diesel motor.
I would at least check the timing positions first before doing anything else; flywheel timing plug, valve covers off to check positions of cams, inspect upper tensioners and chains etc.
Unless of course when I opened the bonnet I could see anything that said different, like a dodgey plug connector on the upper engine harness maybe.
