Alternator Amp Requirement
Old Jun 13, 2020 | 01:51 PM
duddly's Avatar
Default Alternator Amp Requirement
I just bought a used 2006 S-Type VDP, 4.2. with a 100,000 miles. I'm in the process of changing hoses, belt, water pump, alternator, etc. I have the alternator out it appears to be the original one but I can't find any technical information on it. It appears my choices are a rebuilt 140 amp or a new 130 amp. I would prefer going new as it wasn't much fun getting it out so I am wondering if a 130 amp is enough power? Thanks.
Old Jun 13, 2020 | 03:12 PM
scottjh9's Avatar
10 amps should not be a big deal.....i would get a genuine jaguar one because they work all the smart charging systems perfect ....new is pricey, but, you know it is right....there is a battery light that can remain on if you use aftermarket or even sometimes a jaguar rebuild....and like you found out, they are a b...h to change.....i did mine on my 06 str....i swear they built the car around it....if Karl chimes in he can explain the battery light condition better
Old Jun 13, 2020 | 04:46 PM
NBCat's Avatar
You can also take the alternator to an automotive electrical specialist for an overhaul. Then there's no issue with it fitting correctly or having the charge warning lamp constantly on.
Old Jun 13, 2020 | 05:29 PM
duddly's Avatar
A new one is pricey. I wonder why, the label say it's a Denso, which apparently is Nippondenso now. Getting the same one rebuilt sounds like a plan although I was hoping to get one in before I forget how I got it out. Thank you, you have made life much easier.
Old Jun 13, 2020 | 06:13 PM
NBCat's Avatar
In case you don't already have the X202 Workshop Manual, here's a link:
https://www.dropbox.com/s/aq3872pbu5...kshop.pdf?dl=0
The procedure for removing and installing the alternator is in section 414, page 2789.
Old Jun 13, 2020 | 07:51 PM
scottjh9's Avatar
Did you come out the front or the rear....i came out the front like a hard head, but installed from the back like the manual says....i thought taking the motor mount and steering gear loose was too much work....boy was i wrong
Old Jun 13, 2020 | 10:57 PM
duddly's Avatar
It was an experience I hope to forget soon. I had all the front hoses out to change those and the heater valve and was contemplating trying to bring it out that way but I was having a difficult time trying to figure out how the alternator 3 wire connector came unlatched as I couldn't really see it. So, I eventually had to lift the engine to get the motor mount out to unlatch the connector. I didn't do anything with the steering but putting it back in I do believe I'll take the power wire off of the starter as that was the biggest obstacle for me to guiding it out.
Old Jun 13, 2020 | 11:11 PM
duddly's Avatar
Thank you very much for the link. This will be a great help.
Old Jun 13, 2020 | 11:19 PM
scottjh9's Avatar
Yeah, nbcat and a few others are probably chuckling at our out the front experience....that is why this forum is so great.....all the knowledge is here, you just have to ask
Mark Oz
Aug 25, 2018 03:44 PM
Rezzz
Mar 17, 2015 10:05 PM
billj
Sep 18, 2014 05:10 PM
Thermo
Nov 7, 2013 02:28 PM
86XJS
Feb 4, 2009 11:55 PM
