Ambient temperature sender
Old Sep 3, 2018 | 10:42 AM
hak's Avatar
hak
Default Ambient temperature sender
2001 S-type. Had inaccurate readings on the outside temperature, so I replaced the sender. Now the reading is 75 deg F and does not change even thought the outside temp is 86 deg F. Does anyone know the what the voltage at the sender connector should be and the resistance of the sender at room temp.
Thanks,
Howard
Old Sep 3, 2018 | 10:52 AM
JagV8's Avatar
I'd read it via OBD and it sounds like you need to chase the wiring etc.
Old Sep 3, 2018 | 11:46 AM
kr98664's Avatar
Howard, I’m not positive, but think the resistance values are the same as the evaporator and duct temp sensors in the HVAC system. There’s a chart in the middle of post #3 here:
https://www.jaguarforums.com/forum/s...2/#post1714571
From your description, it sounds like you’ve got two things going on. It appears your original sensor was inaccurate. The replacement seems to be failed in a different manner, stuck on one temperature. Play with the two sensors at various temperatures and see what the resistance looks like.
Old Sep 3, 2018 | 01:17 PM
leaping cat's Avatar
see my post no. 10 on that thread.
whyhellothere
Aug 26, 2015 06:47 PM
Eddie6
May 28, 2015 05:12 PM
chippergasman
May 17, 2015 09:02 AM
razorboy
Oct 3, 2014 03:36 PM
Spikepaga
Nov 11, 2013 09:06 PM
