Another Air bag question!!
Old Aug 14, 2016 | 11:43 AM
Lefet's Avatar
Default Another Air bag question!!
2002 S-Type 4.0, airbag light comes on at start up, blinks intermittently 3, 6, 3, 6 (8 times), then stays solid. Any help on where to look to solve the problem? Assistance much appreciated!!
Kevin
Old Aug 14, 2016 | 02:03 PM
JagV8's Avatar
I have that as B2292 centre pretensioner circuit rear - open circuit
but also as possible short to battery (there's a sub-code you don't get via flashes)
Old Aug 15, 2016 | 10:49 AM
clubairth1's Avatar
Community Influencer
Do a search on airbag code 36. Report back what you find.
Common problem.
Old Aug 16, 2016 | 09:08 PM
Warspite's Avatar
Before chasing a number of ghosts, does your cruise control, or steering wheel audio controls work? If not, it's most likely the clock spring. Airbag was first symptom that spread to the others on the steering wheel.
Old Aug 19, 2016 | 12:09 PM
clubairth1's Avatar
That's a good point about the clock spring!
Old Aug 23, 2016 | 09:00 PM
Warspite's Avatar
That's what happened to me. Symptoms get worse over time, until nothing on the steering wheel works.
Old Aug 28, 2016 | 07:15 AM
Lefet's Avatar
Cruise control, audio and everything works on the wheel. The only other things that don't work anymore is the trunk latch (inside), and the back up alarm.
Guy on my job told me the sensor at the front bumper is sticking and to just spray it with some WD40.
And thanks for all the responses, I don't know why I didn't get the email there was any.
joolz
Apr 10, 2016 02:01 PM
kmarajh
Apr 2, 2016 09:43 PM
AJS57
Mar 27, 2016 10:31 AM
Derrick Gasaway
Mar 26, 2016 11:27 PM
