Another A/C thread.
Old Aug 31, 2013 | 02:09 PM
MR_X's Avatar
Default Another A/C thread.
Hello,
Got a friend with a 2005 S Type 4.2. Had a leak in the DCCV and replaced it. Then had the cold air on driver side and hot air on the passenger side. I fixed the CCM and now is better. There is cold air coming out of the passenger side but not as cold as the driver side. What else should I look at?
Old Aug 31, 2013 | 04:47 PM
abonano's Avatar
Could be one of the HVAC servo motors not working properly. (probably blend door servo)
Old Aug 31, 2013 | 07:07 PM
MR_X's Avatar
Don't know what it was but all of the sudden it's working fine now.
Old Sep 1, 2013 | 11:16 PM
MR_X's Avatar
Ok, so now the issue got worst. Now it is blowing super hot hot out of the passenger side and not as cold from the driver side. What else could I look at?
Old Sep 2, 2013 | 08:49 AM
Jon89's Avatar
As abonano advised earlier, check your HVAC servo motors, particularly if you hear bubbling sounds coming from behind the vents just after the engine is switched off....
Old Sep 2, 2013 | 01:02 PM
MR_X's Avatar
Where are the servos located? I'm assuming behind the dash but where exactly.
Old Sep 4, 2013 | 07:50 AM
abonano's Avatar
Not sure on the 05 - but my 00 has a total of 5 servo motors - all mounted on the HVAC assembly in different locations.
3 of the 5 - you have to remove the entire dash to get to them. The recirculate servo is relatively easy to get to (removing the glove box) as I also believe the servo that controls the floor/dash air flow. (driver's side foot well)
Hope this info helps.
Old Sep 4, 2013 | 04:49 PM
MR_X's Avatar
Don't think they are the servos. It resirculates fine in according to their settings. It's just the temperature that can't be controlled.
Old Sep 4, 2013 | 04:58 PM
JagV8's Avatar
It may be them.
Or one or more of the sensors. Plenty of threads about those, just go reading.
Old Sep 4, 2013 | 07:07 PM
abonano's Avatar
To add to JagV8 - one of the servo motors (blend door) controls the flow of air between the evaporator portion (A/C) and heater portion of the HVAC box.
As JagV8 mentioned - there are many threads on the forum tackling this issue... Happy Reading...
Old Sep 4, 2013 | 08:15 PM
Gus's Avatar
Gus
This might help
Link - JaguarClimateControl.com
Old Sep 6, 2013 | 04:02 PM
craig76's Avatar
Default Heater problem
i've got warm air coming out of the drivers side. and cold air coming through the passenger side, no matter what I do I cant change it, even been through the manual step by step, no good, any advice would be greatly appreciated
Old Sep 6, 2013 | 04:39 PM
abonano's Avatar
As previously mentioned - check the servo motors for proper operation. If you have the right scanner - you can perform a test of the HVAC system. There might be servo faults stored in the computer pointing you to the servo(s)... PS - either DCCV or blend door servo...
Old Sep 6, 2013 | 05:09 PM
tbird6's Avatar
Since you changed the DCCV be aware several people have received bad DCCV's right out of the box. So check the three hoses going to the heater to see if they are hot when you have it set to heat and not so hot when you have it set to A/C.
When the DCCV was changed did you do a proper coolant flush and refill? It's important to flush the cooling system and use the proper coolant. The 2005's use Dex-cool and NOT the standard green stuff!
Old Sep 6, 2013 | 06:42 PM
MR_X's Avatar
I used proper coolant and I have a coolant fill tool that put vacuum in the system before filling. So there is no air. I was thinking that maybe the DCCV was faulty out of the box also.
Old Sep 7, 2013 | 05:54 PM
kr98664's Avatar
Dear Mr X,
I got to wondering if this could be a problem with a bad temp sensor causing the controller to command an output that is incorrect. I recently fixed a slightly different climate control problem after finding a bad temp sensor, therefore all vaguely similar problems must be caused by the same issue <VBG>:
https://www.jaguarforums.com/forum/s...1494&styleid=4
It would be easy enough to check the 3 sensors under the dash. Two are on the left side and one is on the right. Of the two on the left, I believe the upper one (also closer to the vehicle centerline) is the main evaporator discharge temp sensor. The other two are for the ducts feeding their respective sides. If one of these has gone bad, the controller may not realize it and think it still has a valid duct temp reading.
As a honorary Scotsman, I like to rule out the cheap and easy stuff first. If you have a wiring diagram, you can read the resistance values for each sensor from the plug on the back of the controller. Or you can pop out each sensor and read them individually. Details of the sensor locations are about halfway down on this page:
http://jaguarclimatecontrol.com/diagnose/
The first link above has the Ford part number and details of the expected resistance values. You should see about 31k ohms with the sensor at 70 degrees F. There is another thread with a chart for various temperatures, but I can't find it right now.
Old Sep 7, 2013 | 06:17 PM
MR_X's Avatar
Thanks for the tips and explanation.
Question, to test the sensors, do I have to take them out? Is refrigerant/coolant going to come out?
I don't know to what temperature to test them at since I really don't know at what temperature is blowing out.
Old Sep 7, 2013 | 06:19 PM
As a full blooded Scotsman I took mine out and put them in the freezer and than compared the resistance as they warmed up. I assumed (I know) that all three would not be toast so if they matched they had to be good.
Old Sep 7, 2013 | 06:21 PM
They are in the air flow so no leaks when you take them out, it does help if you are a double jointed midget.
MR_X's Avatar
^LOL I guess my son will be helping out.
dan102877
Sep 29, 2015 06:47 PM
oldjaglover
Sep 29, 2015 03:27 PM
bydand
Sep 28, 2015 09:47 AM
bydand
Sep 27, 2015 12:00 PM
