another climate control thread
Old Jun 21, 2012 | 05:58 PM
barcheta's Avatar
Default another climate control thread
Its been fairly warm the last couple of days here. Yesterday, I decided to drive the jag to work. Early morning running the AC on a cold engine produced very cold air. Nice. A few hours later I break for lunch and decide to take the car out. AC on warm engine producing very wam air. Not nice.
So I get the car home and throw it up on my lift to have a look at the compressor. I check for leaks and then see if it needs any 134a. It doesn't. With the engine running and the AC on ful blast, the compressor doesn't even appear to be cycling. Baffled and thinking I have a bad compressor, I call it night and decide to let my mechanic have a crack at it.
THis afternoon I pull it down from the lift, and start it to leave it outside so he can come and get it. Now the AC is blowing ice cold again. WTF?
I drive it around for a bit. Park it for a about an hour. Go to restart and presto it's vblowing hot air again. I do not think it's the DCCV but wanted to see if anyone else had or knew of this problem.
TIA
Old Jun 21, 2012 | 06:14 PM
JagV8's Avatar
Could be any of the sensors, such as the ext temp one (an easy one to check as its value is on the panel),
When it's faulty again, check the LCD panel. If ext temp is OK, cycle climate from HI to LO and back a couple of times, hoping that if it's the DCCV it'll free up.
Old Jun 21, 2012 | 06:19 PM
barcheta's Avatar
Thanks. I actually tried the cycling Hi to Lo technique. I forgot to mention that. It did seem that when it was cycled to Hi the temp actually seemed a tiny bit cooler. Lo was still stupid hot. I did this probably 3 times before giving up and turning it off.
The value of the temp sensor seemed to be in line with the exterior temp.
Old Jun 22, 2012 | 08:42 AM
Jon89's Avatar
Do you have a mechanic's stethoscope? If so, listen to your compressor with it. If it sounds like a cement mixer inside, your compressor is in the early stages of failure....
Old Jun 22, 2012 | 05:13 PM
barcheta's Avatar
Thanks Jon indeed I do. I'll take a listen and see.
I will say though that after reading through jaguarclimatecontrol.com I may be leaning towards a bad DCCV.
Old Jun 22, 2012 | 06:40 PM
For a quick check clamp off the heater hoses and take the valve out of the equation.
Old Jun 22, 2012 | 08:51 PM
barcheta's Avatar
Thanks Norri. I will try that
Old Jun 22, 2012 | 09:46 PM
Precha's Avatar
I will do the same my problems but mine stopped after replacing the dccv some say my control panel maybe bad now ??? I will have it checked. good luck with yours!
Old Jun 22, 2012 | 10:01 PM
bfsgross's Avatar
Precha send the CCM to the outfit mentioned on this forum. They'll rebuid it for $125.
Old Jun 24, 2012 | 08:31 AM
Precha's Avatar
Yea I am going to check out this shop in Dallas, they say he can figure it out ! Thanks
Old Jun 25, 2012 | 10:18 PM
idouoooo's Avatar
I had that same exact problem till the ACCM went out and it was just hot air all the time. I opened it up and fixed it my self and improved it a little. its been working fine for about a year now
Old Jul 9, 2012 | 01:07 AM
65ras's Avatar
I just wanted cold air so I grounded the 1st and 3rd wires to the heater solenoids till I can troubleshoot. The air is ice cold now. Started the day cutting off the oxidized low valve above the core thread and soldered a schraeder valve to the core threads, then put a R-134a adapter on. The steel was too far gone to hold a hose fitting.
Old Aug 15, 2012 | 08:15 AM
barcheta's Avatar
Haven't had alot of time to follow up with this. I replaced the sensor behind the glovebox. (I think in an 01 there is only the one sensor back there?) I put in a new DCCV and replaced the ambient air temp sensor in the dash since it was a cheap part. I even had the RCCM out to inspect. It looked fine with no obvious signs of heat damage or burned solder points. At this point I'm think either compressor or pressure valve. I did try to add 134a but the compressor didn't act like it was cycling on to pull in any charge.
Old Aug 15, 2012 | 09:15 AM
steveinfrance's Avatar
Do you have CCS panel codes on these cars?
Ignition off, hold down Auto and Recirc, turn on ignition
Press Auto to get error codes, Face to cycle through them.
XJsc-guy
Sep 25, 2015 11:09 AM
neckstrap
US Western
Sep 10, 2015 10:44 PM
texaspete
Sep 10, 2015 08:34 AM
1964Daimler
Sep 9, 2015 04:50 PM
tberg
Sep 7, 2015 07:32 AM
