Auto gearbox problems
Old May 17, 2014 | 07:15 PM
Havelet2013's Avatar
Default Auto gearbox problems
Hi All,
As I have put in my new member section, my Father in Law bought a 2003 2.5l S Type about a month ago and two weeks later I have now got a 2003 3.0l S Type, as I loved his car so much. I will come onto my Father in Laws problems at a later date. My car has been well looked after and has full service history and is a dream to drive. The one problem I have is with the auto gearbox. I have been reading a lot of posts about the problems with the gearbox, but can't quite find anything similar to mine. The gearbox doesn't have the lurch and goes though all gears 1 to 4 smoothly until you get to go into 5 and 6. the revs build up to about 2000 and you then see the rev counter drop as it goes in to gear, if you try and accelerate, even lightly the rev counter fluctuates about 100 rev each side and sometimes you can hear a sort pulsating rubbing noise from underneath.
As the revs then build up to 2000 again it will go smoothly into 6th and then do the same again. If you take it for a run on the motorway the fluctuation stops and it drives fine, also as you slow down it is very smooth in all gear as it changes down. I have no gearbox warning lights. Does this sound like an expensive problem or shall I just grin and bare it. I can live with it but it is a bit annoying when you have people in the car.
Thank you for any help
Old May 17, 2014 | 08:51 PM
You are new, so welcome to the real world.
My best guess, and knowing very little of the 6 speed units, is to change the trans fluid and filter (which is the pan in this case).
The distance travelled means little in my opinion, it is 11 years old, and even with "dealer" service, the trans fluid is "sealed for life", HAHA, and they WILL NOT touch it.
Second guess, is an electrical gremlin, which can "mostly" be sorted by disconnected the battery, go have a drink (cup of tea for the colonies), then reconnect, and observe any changes.
Old May 17, 2014 | 09:26 PM
campaign308's Avatar
As user Grant Francis said change the trans fluid/filter...I had a few issues with my 05 S-Type...RPM's would fluctuate randomly...would get a gearbox fault code just by switching gear to reverse, hard shifts...once I changed the trans fluid & filter(pan) on my s-type all that went away...I can't guarantee it'll fix your issue but possibly could....I'd start with what Grant said about the battery first !
Good luck
Old May 17, 2014 | 11:39 PM
police666's Avatar
Sounds like classic torque converter starting to fail to me.
Old May 18, 2014 | 01:25 AM
Thank you for your help, I was starting to feel optimistic and them Police666 ruined it, as that was exactly what was worrying about.
I will try and get the fluid changed first and hope for the best.
Thanks again
Old May 18, 2014 | 01:51 AM
The torque convertor failure should post a code, which slips my memory for the moment.
Have you had them checked? It does sound like it could be the TC.
Old May 18, 2014 | 01:56 AM
I have only checked for a fault code on the engine, I will have to go for a gearbox ecu check at the dealers. There is an independent not that far away might try them.
Old May 18, 2014 | 02:34 AM
wearlej's Avatar
Banned
Ask to the Indy to check the condition of the trans fluid, also ask them if it has any emulsification...
Old May 18, 2014 | 02:38 AM
It's P0741 the TSB was S307-03 you can find it on Gus's site.
JagRepair.com - Jaguar Repair Information Resource
Old May 18, 2014 | 08:19 AM
Just been out for a non stop journey around town for about an hour, the gearbox has been changing as sweet as a nut. If it was the TC would it not be bad all the time?
Old May 18, 2014 | 08:35 AM
police666's Avatar
Not nessaceraly, have a look at the UK forum, the have been a few needing replacing with same symptoms as you and no codes (they tried fluid and filter change first) it only seemed to be noticed in 5th or 6th at first but gets worse over time.
I'm guessing here but it might not throw codes as it's not completely failed only starting to??
It might not be the TC at all, I really hope it's not.
Old May 18, 2014 | 10:24 AM
Mikey's Avatar
Correct.
My car does the same thing as yours- problem disappears as the gearbox reaches normal operating temp. Jag issued TSB S307-14 on the subject in 2003
"Summary
S307-14: This Technical Bulletin has been issued to address a customer concern of a surge in
excess of 150rpm during engine warm up, at a temperature of 30°C to 50°C and at a vehicle speed
in the region of 40mph (64.3kph) to 60mph (96.5kph)"
Sound about right?
"Action
Should a customer express a concern, the Transmission Control Module (TCM) should be reconfigured
using the Worldwide Diagnostic System (WDS) with software release JTP 759/27 or later."
The entire bulletin can be downloaded from the stickies at the top I believe.
Old May 18, 2014 | 11:12 AM
Thanks again Police666 and thank you Mikey, will see what the indy thinks in the week.
Old May 19, 2014 | 07:06 AM
DaveMcNally's Avatar
Default Gearbox Problem
Hi I can't give advice but I did have the same problem and tried everything before I went to an Auto Gearbox specialist. I wish I had gone there first and saved a fortune - I replaced EGR valves (2) - had the oil tested (no problem) diagnostic tests - the lot! The Jag dealer had recommended a replacement gear box the specialist repaired it for half the money!
Old May 20, 2014 | 03:47 AM
Hi Dave, Thank you for your help. Please could you tell tell me roughly how much it would be to replace the two valves?
Old May 20, 2014 | 01:10 PM
tbird6's Avatar
The car only has one EGR valve. Did the new one go bad too?
Old May 21, 2014 | 06:08 AM
OK - background first - I am not a mechanic but I tinker with old motorbikes and used to do all my own servicing (40 years ago - cars were very different then!). I now leave all my servicing and repairs to an independent jag specialist (the jag Centre - Norwich). Down to business - I had both EGR's replaced (I am assured that my exhaust has one on each side). The valve and de-port valve kit for each side was approx. £160 plus VAT. labour to fit both was approx. £90 and the investigation of the fault was £50. - the total was approx. £360. The right hand side was done as part of a service with a 10% reduction on costs but the prices are similar.
There were faults with both these valves logged as fault code P140A-00 (- not sure what that means). When this work did not clear the problem (£720 worth!) the garage recommended replace the torque convertor.
If your car shudders under moderate acceleration and makes a "mild growling" noise at times that seems to come from under the front passenger seat - go to an auto gear box specialist. My box has a new torque convertor, beefed up bushes? and an air cooler for the coolant and works perfectly (but I don't tow a caravan before the "experts" jump on me!)
Hope this helps
Dave
Old May 21, 2014 | 07:03 AM
JagV8's Avatar
Which engine is it??? Sounds like the diesel
Old May 21, 2014 | 10:41 AM
Mikey's Avatar
Hope this helps
Dave
There's two completely different transmission faults being discussed. The first is a mechanical failure of the torque converter and the second is a software flaw.
The original software occasionally allowed the T/C to engage before the transmission was fully warmed up. This resulted in a bit of engine RPM hunting as seen on the tachometer. The problem disappears once normal operating temperatures are achieved. It seems that this is what the OP is describing. The revised software delays engagement of the T/C with a cold transmission.
Old May 21, 2014 | 12:37 PM
tbird6's Avatar
All good advice and I would add to check fluid level first then apply TCM update and then change the fluid and filter.
It looks like even the diesel has only one EGR valve. I can't think why you would need more than one anyway? All it does is feed exhaust back into the intake so one valve will do that.
I have never seen a car with two EGR valves? Has anybody else?
Wolfy
May 28, 2024 08:06 AM
cissdm
May 3, 2016 06:02 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
pnwrs2000
Sep 3, 2015 11:55 AM
