Auto-On headlights work again?
Old Jan 31, 2011 | 04:32 PM
Patrick E's Avatar
BFS,
Any update on your headlight sensor situation? I have the same problem and am probably going to replace the sensor. Has anyone done this? Do you have to take the dash off, or can you go through the firewall or just turn and pull the sensor straight out?
Thanks in advance.
Old Jan 31, 2011 | 07:53 PM
bfsgross's Avatar
Hi Patrick. The auto headlights cont. to be unoperational and I saved this issue for the spring. I've read that the pillar trim must be removed in order to lift the dash pad to access the sensor. Please let me know how it goes.
Old Feb 1, 2011 | 06:32 PM
androulakis's Avatar
You boys realize you can test the sensor by jumpering two wires behind the instrument cluster. I'd do that before I went ahead with ripping the dash apart...
Here's the diagram.
Take care,
George
File Type: pdf
Old Feb 25, 2011 | 02:32 AM
JagV8's Avatar
To save ripping things apart, the ICM can be asked what input it sees. In AutoEnginuity:
Exterior Lamp Night Day Sensor
Then cover and uncover the sensor.
I expect IDS and maybe WDS can also read it.
Old Feb 25, 2011 | 07:30 AM
bfsgross's Avatar
Thanks for the info George. Yes jagv8, the Jag mechanic said the same on hooking her up to a reader. Thanks the same.
afterburner1
Dec 16, 2015 12:12 AM
philwarner
Sep 5, 2015 10:05 AM
mcdutch
Sep 4, 2015 03:38 AM
laserguy
Sep 3, 2015 02:02 PM
King Charles
Sep 3, 2015 12:40 AM
