Auxiliary pump leaking
Old May 22, 2021 | 11:45 AM
Extinct's Avatar
Default Auxiliary pump leaking
So after completing my coolant hose replacement work I still have a small leak, looks like it might be the auxiliary pump. Do those fail and leak out of the body? What a pain in the *** to get to. I hate to remove all the hoses and what not only to find out that is not it.
Old May 22, 2021 | 12:30 PM
Aarcuda's Avatar
Ive never read another post where anyone complained of a pump leaking. So you’ll probably have to look
Old May 22, 2021 | 11:23 PM
abonano's Avatar
Yes, it is possible for them to leak through the body. (There is an o ring between both pieces) and yes a PITA to swap out as well.
Don't leave it like that. Swap it out!
Old May 23, 2021 | 10:32 AM
motorcarman's Avatar
I have had to replace several electric pumps. I even had on fail and take out the A'C clutch/pump motor fuse.
The A/C clutch was inop and the fuse was blown. I changed the fuse and the fuse 'blew' again.
I unplugged the pump motor and the A/C worked normally.
Ended up replacing the pump moor.
cooldood
Nov 4, 2021 08:14 PM
cooldood
Nov 17, 2014 09:33 PM
kats98
Nov 23, 2013 03:53 PM
leaperjag
Jul 13, 2009 08:31 PM
jerry_hoback
XJ40 ( XJ81 )
May 9, 2007 09:21 AM
