B codes
Old May 23, 2017 | 04:08 PM
Kewpie's Avatar
Default B codes
I pulled the following codes, erased them, drove around and they re-appeared.
b2784
u2520
b1264
B1676
B1262
B1265
b1263
B1242
What to do?
Old May 23, 2017 | 11:32 PM
jagstuart's Avatar
try reading this:
https://www.jaguarforums.com/forum/s...t-fault-94932/
Old May 24, 2017 | 06:37 AM
JagV8's Avatar
Post far more car details!
Old May 24, 2017 | 08:06 AM
Mikey's Avatar
b2784
u2520
b1264
B1676
B1262
B1265
b1263
B1242
What to do?
Usually finding those codes means that the system doesn't work properly and that the thing needs work. Is this the case?
Old May 24, 2017 | 08:16 AM
Kewpie's Avatar
Replaced the dccv twice, aux. water pump, thermostat, blower motor, rccm, checked all sensor in dash and under. AC still blows hot. Could it be a blend door that is allowing the hot air to come in? compressor works, lines are cold.
Old May 24, 2017 | 09:07 AM
JagV8's Avatar
Work through - JaguarClimateControl.com
Old May 24, 2017 | 09:28 AM
Kewpie's Avatar
that has been done repeatedly
Old May 24, 2017 | 09:42 AM
motorcarman's Avatar
DTC guide for the X202
bob
File Type: pdf
Old May 24, 2017 | 11:13 AM
JagV8's Avatar
So which of its tests fail?
Terse answers with little data do mean very slow diagnosis.
Old May 24, 2017 | 11:27 AM
aholbro1's Avatar
No. At least not by itself. With Climate control set to "Lo" the DCCV should never allow coolant to go to the heater core. At other settings, it will modulate as-needed. Sounds like your DCCV is allowing coolant to the core when it shouldn't. You will need to determine if it is being commanded to open when it shouldn't? or if it is opening when commanded closed from the control?
I'll assume since your a/c lines are cold, that you have cold register air for the first minute or three after a cold-start, before the engine coolant begins to warm up?
Old May 24, 2017 | 12:44 PM
Kewpie's Avatar
sounds like I have a lot to check on, thanks for the help
