Battery Dead Again
Old Mar 21, 2013 | 02:23 AM
JagV8's Avatar
Car takes about 40 mins to shut down. Then it should be a few tens of mA. Less than 100mA (0.1A).
Old Mar 21, 2013 | 03:29 AM
steveinfrance's Avatar
As JagV8 says that's 700 mA - far too much if you waited for it to go to sleep.
You need to lock the car (with your clamp on the boot switch of course).
Old Mar 21, 2013 | 02:12 PM
JOsworth's Avatar
Umm.. Daryl,
Did you do a search and read the threads where the Tech User BRUTAL talks about the ignition switch?
Old Mar 22, 2013 | 08:20 PM
hotstr's Avatar
had a problem like that about a year ago the relay that picks up the ac clutch was staying on intermintly picking up the clutch replaced the relay had no more problems tapping on the relay turned it on and off thats how i found it
Old Mar 25, 2013 | 08:10 PM
drun's Avatar
My '01 did this (drove me bonkers). Then I read on here from a guy working at a jag dealership said try changing out the back half of the ignition switch,(he said it goes bad so often they don't even troubleshoot anymore,just change the electronic part of the switch).
I did and voila, my battery nightmare disapeared. I tried everthing (the 2 wires in the trunk,everything and spent big $$$). No mas problemas senor!
Old Mar 26, 2013 | 02:32 AM
JagV8's Avatar
That'll be the part Brutal's mentioned. Well reminded.
Old Mar 26, 2013 | 11:24 AM
JOsworth's Avatar
I've been trying to tell people....
Old Mar 26, 2013 | 11:28 AM
  #28
JagV8's Avatar
Did someone say something?
Old Mar 29, 2013 | 01:05 PM
Try2DIY's Avatar
I have this problem.
The ignition switch, if left in position to allow radio to work, will shut down radio, possibly indicating a good sleep switchover.
Interior lights shut off after 30 seconds or so.
Trunk light isn't working.
Will check on jimgoose's trailer connector. No moisture in trunk though.
I checked visor vanity mirror lights, defrosters, radio, headlight switch.
Temporarily I am running with a second battery and well-secured jumper cables connected all the time, carefree so far, extending time between random batt rundown. Anybody want to warn me on that, as far as no fancy electronic switchover there?
Old Apr 27, 2013 | 02:26 PM
  #30
bliving7's Avatar
Hi,
If you have not solved the problem put a Battery Buddy on the battery. It shuts the battery off at a preset voltage so that you don't start your morning with a dead battery. There is even a wireless remote to reset from inside your car. This is not a cure of course.
My high school daughter was always leaving a light on or something and it put one of these devices on her car and it worked like a champ
bliving7
Dagny
Jun 11, 2024 01:06 PM
99xk8guy
May 28, 2024 09:36 PM
Rivguy
Nov 13, 2022 02:55 AM
ferraripete
Sep 12, 2016 09:02 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
