Battery dead manual locks cannot open
Old Jun 23, 2013 | 09:35 PM
Krp's Avatar
Krp
Default Battery dead manual locks cannot open
Hi I have a 2000 jaguar s type. i haven't used it for a month. The battery is dead and I cannot turn the key hole manually in the driver side and at the trunk. Its so hard to turn it might break the key. Is there any negative and positive terminal going to the battery that I can tap so that I can use my remote. I hope someone can help thanks
Old Jun 24, 2013 | 02:20 AM
Welcome to the forum Krp,
I've moved your question from Jaguar Forums Advice / Feedback & Suggestion Center section to S-Type section. Members here with the same model will be able to advise on accessing terminals.
When you get a minute, please follow this link https://www.jaguarforums.com/forum/n...-intro-must-5/ to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Jun 24, 2013 | 03:38 AM
JagV8's Avatar
Please use Search to get the answers (there are several ways but starter motor is probably easiest for you). Your key should work in the trunk (boot) lock, regardless. Behind the letter U of jaguar.
Old Jun 24, 2013 | 03:44 AM
jimbov8's Avatar
Try spraying some WD40 in the boot lock and then working it with the key. It should free up enough to then open.
Old Jun 24, 2013 | 04:19 AM
thebiglad's Avatar
It doesn't sound like an electrical fault me (the locks not working manually) so I'm guessing they are just fouled up with lack of use.
I would use brake and clutch cleaner to blast out the lock barrels, they should work ok then.
Old Jun 24, 2013 | 05:14 PM
grandhaze's Avatar
you got the right key?
Old Jun 25, 2013 | 06:52 AM
police666's Avatar
I was just about to say that, have you opened the door or boot with the key before?
Old Jun 27, 2013 | 10:24 AM
Krp's Avatar
Krp
I already opened the car door. I took of the right front tire and connected the terminal from the starter motor to a battery and the car opened thru remote. The key that I'm using is the same key I use with the ignition and it came from the dealer maybe I need to put oil with the mechanisms anyway guys thanks for the tips
Old Jun 27, 2013 | 11:16 AM
police666's Avatar
I oil and test all keys and locks every month, also oil/grease all hinges and bonnet pull/catches
Old Jun 27, 2013 | 11:48 AM
tbird6's Avatar
For any locks try to stay away from regular lubricants. Powdered graphite is cheap and easy to find at any parts store. Lubricants attract dirt and grime which gum up the locks with time.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
XJsc-guy
Nov 23, 2015 01:56 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
