battery drain
Old Apr 6, 2012 | 03:46 PM
gerdam09's Avatar
Default battery drain
hi guys,i hav 2 problems.my jag battery dies after about 2 days.and just b4 that the alarm goes off then i know the battery is going flat.ive checked the forum for answers so i took a reading of the current with my dvom and the amps drops from 4amps and after 30 mins drops to .65 amps noticed that the 4 relays are still on after an hour and if i remove them 1 at a time the current drops to .08amps.can anyone please tell me how to get to the gecm and primary junction box.i know where there are but dont know how to get to them,i think i might have to replace a cable,thanks
Old Apr 6, 2012 | 05:24 PM
JagV8's Avatar
Hunt for JTIS or similar. Full info.
Old Apr 6, 2012 | 06:07 PM
00gkingr's Avatar
as a jaguar tech I have had may battery drain faults with s type. 2 most common is the duo valve in the heating system also if your alarm is going off there is a wire that runs from the fuse box on the left hand side to the front electronics module that powers part of that module. the wire runs behind the front bumper. if that wire looses some or all of its 12v the car will think it is being stolen and wake a lot of they systems up. sometimes this will set the alarm up. check the powers and grounds to the fem and if you find any faults don't look for them on the wire as you will never find them the wire is far to long. just run a new wire from the fuse box to the fem. i can honestly say that 99% of battery drains and alarms going off are caused by this fault
Old Apr 6, 2012 | 06:09 PM
00gkingr's Avatar
to get to the gems you need to remove the right hand boot carpet and remove the black panel that you can see the module is bolted to the back of there. also the primary fuse box is in the right hand footwell. remove the trim and you will see it.
Old Apr 7, 2012 | 10:49 AM
gerdam09's Avatar
thanks guys ,will have a go at it on my next off days next week,and will keep you updated.
aholbro1
Dec 29, 2024 06:46 PM
lighterthanair
Sep 24, 2015 08:36 PM
puddled
Sep 22, 2015 03:57 AM
Charlene n John
Sep 14, 2015 10:08 AM
obwoodie
Sep 3, 2015 07:45 PM
