Battery drain/car dead
Old May 8, 2023 | 02:01 PM
  #41
kr98664's Avatar
Try it both ways.
(Not that there’s anything wrong with that…)
Old May 11, 2023 | 08:31 AM
  #42
kr98664's Avatar
Any updates?
Old May 11, 2023 | 09:57 AM
  #43
blazarus's Avatar
Originally Posted by kr98664
Any updates?
not yet as I’ve been at work, will have a look again Saturday. I’ve got the barrel from boot out and operating it on a cable I pull through the back seats, I’ve got two batteries so if I stop I can swap over.
Old May 11, 2023 | 05:16 PM
  #44
blazarus's Avatar
Any updates?
got a update…. Driving to work tonight and the center screen went off whilst driving… followed by abs, gearbox dcs faults, battery light came on then steering went…. Managed to pull into a garage which was closed and changed battery as I took a spare… popped the bonnet and again smoke out of it but this time there were embers at the bottom, have a vid of it. After I changed battery I limped home instead of going to work. Could there be a earth problem?
Old May 11, 2023 | 07:55 PM
  #45
Aarcuda's Avatar
It looks to be right about where your alternator is. I will check to see if there are any wires that are rubbing up against the engine shorting out
Old May 11, 2023 | 08:32 PM
  #46
blazarus's Avatar
I’ve tried posting a vid but it won’t upload, if that’s the case could that be the route of my issues? I do appreciate all the guidance. I bought the car in January and have had nothing but grief.
I drove the car home and the glow had gone so I’d assume the air cooled it?
Old May 12, 2023 | 08:03 AM
  #47
kr98664's Avatar
Yeah, I'd say that's an update. First things first, if the car is somehow spitting out glowing embers, do not continue driving it as is. Whatever the root cause may be, it needs immediate attention before causing a fire.
Give the wiring in that area a good visual inspection, especially the heavy cable. If you don't find any places worn from rubbing against ground, your most likely culprit is the alternator itself.
Old May 12, 2023 | 08:35 AM
  #48
blazarus's Avatar
oh for sure it’s not being driven now, I’ve likely lost my new job over it as I’ve broken down like 3 times in the first two weeks lol. I mean I changed the battery and limped home but then took the battery off. Here’s something before I put on charge the battery that was on when it went sideways I thought I’d check it’s voltage.. was 12.08 which is clearly enough to crank, sure not ideal but it wasn’t flat like prior, perhaps the embers were a blessing kinda as it may be a indicator as to where to look.
When I got home and lifted the bonnet there was no glowing so I assume the slow plod home must’ve cooled it. I realise moving it was a dangerous play but sitting next to a petrol pump seemed dangerous to. So the alternator seems to charge when stationary as the voltage on battery goes up but when it runs there’s friction, I don’t know but could the vibration of driving cause wires near there to rub when they shouldn’t?
Old May 12, 2023 | 01:08 PM
  #49
scrannel's Avatar
Please... don't start any forest fires!
Old May 12, 2023 | 02:22 PM
  #50
JagV8's Avatar
"embers" - very bad, sadly.
Maybe a loose/chafed wire shorting against something.
Old May 12, 2023 | 03:31 PM
  #51
kr98664's Avatar
Keep in mind the alternator has a cooling fan for internal cooling. If something inside melted down, the fan could eject molten debris.
Old May 12, 2023 | 04:00 PM
  #52
blazarus's Avatar
I know it’s not ideal but if it’s the alternator I’d be glad to know what’s causing the grief.
Old May 12, 2023 | 06:27 PM
  #53
S-Type Owner's Avatar
The deeshul variant was never sold over here "across the pond," but as I recall, things are crammed in the engine bay pretty snugly, so getting an adequate view from above may prove problematical. Do you have access to a lift so a proper look-see can be undertaken from below... ?
Old May 21, 2023 | 09:24 PM
  #54
blazarus's Avatar
Default Update
Just a update, my dads just repairing his lift. Once that’s done we will lift her up and have a look at the old girl.
Old Jun 30, 2023 | 03:23 AM
  #55
blazarus's Avatar
Im getting the alternator replaced in the next two weeks, been busy at work so not had the time to mess with it
CA Jag
Apr 10, 2023 08:24 PM
Forcedair1
May 31, 2019 01:03 PM
Eos
Apr 19, 2019 11:12 AM
dtrain
XJ40 ( XJ81 )
Oct 3, 2012 09:01 AM
Rique
May 8, 2012 09:05 PM
