BIG ISSUES with the 05 s type
Old Feb 15, 2010 | 06:55 PM
JagV8's Avatar
No reason you should know this, but any auto shop should: any car can have these issues. Next someone gets to figure out why. They're very well known: battery not charging properly, bad connection, damp/water getting in somewhere, etc. We can probably talk you through them if you want to DIY but you'll need time, tools, patience and other stuff that escapes me right now. So, DIY or auto shop? Anyone with ideas chime in
Old Feb 15, 2010 | 09:16 PM
MissChelle's Avatar
k i'll take it in.. i put a new battery in it last week and i needed it jumped today.. hmm.. glad all i needed was a jump, but i shouldn't have that problem given that I have a brand new battery. So its something else that is an issue. Oh boy =)
Old Feb 16, 2010 | 04:18 AM
Leedsman's Avatar
Simples says the meerkat: If you don't put some current in, you won't get any current out. A new battery when being held up by the car's charging system (engine running, alternator charging) will read precisely 14.4volt on a digital voltmeter. I've seen these DVMs for as little as a fiver in the cheap shops. Stop the engine and it will fall to around 12.6volt pretty quickly, esp. if there's a load like headlamps.
If you don't get 14.4volt with engine running, check alternator drive belt that it's not skidding on the pulleys (the classic shriek as engine is revved up from idle). A skidding belt gives a charge, but a poor one. Otherwise it's a new/reconditioned alternator.
Leedsman.
Old Feb 16, 2010 | 09:07 AM
Riski's Avatar
Do you leave your car outside over night or do you have a garage?
Sometimes the cold weather can drain a battery down if not started in a while.....and here in the midwest it can get stupid cold!
stanjag
Dec 29, 2024 08:26 PM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
ogorir
Sep 3, 2015 07:34 PM
Spikepaga
Aug 30, 2015 12:59 PM
NinoGrimace
Aug 26, 2015 05:15 AM
