Bleeded brembo STR 2003 and still really bad
Old Jun 13, 2016 | 02:12 AM
slimali's Avatar
Default Bleeded brembo STR 2003 and still really bad
My car isn't braking like a supercar is suppose to brake .Even my honda civic 2000 brakes 2-3 times better. I bleeded the brakes and changed the front rotors 365mm (eurotek) and pads (textar) all on the same appointment. The first day was okay because the rotors and pads where still new maybe so I ignored the braking level. 2 full tanks later... Still the same as before the bleeding and even felt like im almost going to touch the floor when braking. Me and I my mechanic didn't notice any leak. Do I need a 2nd bleeding ? Need help ! Any ideas ?!
Old Jun 13, 2016 | 02:33 AM
JagV8's Avatar
Vacuum leak?
Check fuel trims.
If and only if they are good then you probably failed to bleed the brakes properly. (I wonder if you followed the proper procedure...)
Old Jun 13, 2016 | 03:13 AM
slimali's Avatar
Originally Posted by JagV8
Vacuum leak?
Check fuel trims.
One of my best friend did it. Only european pro garahe shop from benz to lambo. He said we might do another bleeding just to be sure. Just trying to have ideas. Thanks for the reply. If you have more info feel free. 😁
Old Jun 13, 2016 | 03:15 AM
slimali's Avatar
Vacuum leak?
Check fuel trims.
I have a PCM valve (check engine code) can it affects the braking. My mechanic said it helps the brake pump usually. ???
Old Jun 13, 2016 | 03:35 AM
slimali's Avatar
Originally Posted by slimali
i have a pcm valve (check engine code) can it affects the braking. My mechanic said it helps the brake pump usually. ???
pcc valve *** i meant
Old Jun 13, 2016 | 03:52 AM
JagV8's Avatar
You're going to need cat(s) if you don't fix air leak(s) soon.
Any air leak can affect braking. This is brakes-101! Your mechanic appears not so great. Brakes are brakes.
Old Jun 13, 2016 | 03:58 AM
slimali's Avatar
Jaguar Are really rare here in Montreal, Canada. I have two pro mechanic one for jag only but he is so busy it's hard for me to make it check. And the other mechanic is a mercedes w pro. He never get jaguar to fix but always have some ideas... He always have this starter idea that hits him after checking the car for 5-10 mins (quick diagnose). Trying to have more info from this forums instead of payint alot. Now i will take thos seriously for the PCC VALVE.
mikechinea
Apr 16, 2017 05:27 PM
Woznaldo
Jul 20, 2016 02:24 AM
multiplecats
General Tech Help
27
Apr 5, 2016 09:42 AM
oyster
Apr 3, 2016 09:41 AM
Wayne'sJaguar
Apr 2, 2016 05:51 PM
