Blue tooth
Old Dec 30, 2018 | 10:02 AM
Tom Leveque's Avatar
Default Blue tooth
Im having trouble figuring out whether I have Bluetooth on my 2007 S-Type. Some paperwork says I do but I get a No Phone message.
Old Dec 30, 2018 | 10:40 AM
cubist's Avatar
Hi There,
Check first that you have a Bluetooth Module installed in the car. It's located under the tray in the centre armrest which can be easily removed. The Bluetooth Module, if fitted, has a cable connector toward the rear of the compartment and the module itself is mounted on the right hand side and just underneath the lip the tray sits on when in place.
If the module is there and connected try a pin test to see if there is power to the module. It may be worthwhile checking the Set Up menu to see if Bluetooth is 'enabled' before doing any of the above.
Hope this helps.
Cheers,
Cubist
Old Dec 30, 2018 | 01:37 PM
JagV8's Avatar
I think you can have BT but no phone unless you provide/pair one. The full manual is online somewhere (or was).
Old Dec 31, 2018 | 03:04 PM
Joedotcom's Avatar
hi
this is simple search for bluetooth devices, if you find Jaguar, your car has it,
if theres no jaguar when you search you dont have
its that simple
bluetooth was no a cheap option, so most cars dont have it
cheers
Joe.
Old Jan 10, 2019 | 04:26 PM
JaguarJacks's Avatar
Pure Gold !
$14
Old Jan 14, 2019 | 04:52 PM
Arelem's Avatar
Originally Posted by JaguarJacks
Pure Gold !
$14
I have one of the VicTsing units for my car. Only 2 problems I have had. The neck is not long enough or bendy enough and it interferes with the shifter. The other is, if I have my phone paired and streaming music to the radio, if I plug the phone in to charge, the FM signal degrades and interference starts to bleed through.
Old Jan 14, 2019 | 05:40 PM
Thats probably cause you got the older version
Bro , get This particular edition (the latest) and see the difference
earl08
20
Jan 15, 2019 06:23 AM
bd6047
Mar 9, 2008 02:25 PM
bd6047
Feb 29, 2008 07:16 PM
Cajun Mojo
Nov 9, 2007 04:12 PM
1fstjag
Sep 3, 2007 07:53 PM
