Blue tooth help needed
Old Mar 19, 2008 | 04:37 PM
earl08's Avatar
Default Blue tooth help needed
I hope one of the techs can help me.
For the last 2 days when I press the phone button, I get only message that the handset is in use.
Can someone tell me how to get it to connect to my phoneagain?
its an 08 S-type 4.2
thanks
Old Mar 19, 2008 | 04:50 PM
jag_genius's Avatar
Default RE: Blue tooth help needed
sometime the bluetooth software gets jammed up.. try disconnecting your battery in the trunk..for couple minutes..
Old Mar 19, 2008 | 05:29 PM
earl08's Avatar
Thanks jag_genius,
I found that on a search, I left it off for about 15 mins. No Joy.
I guess its dealer time
what are the current nav dvd and software levels for my car???
Old Mar 19, 2008 | 05:34 PM
jag_genius's Avatar
i think it's v 90 havent seen that disc in a while..
Old Mar 19, 2008 | 07:38 PM
FactoryJaguarTech's Avatar
To fix the handset in use thing, I normally disconnect the BTUM with ignition on. Then plug it back in, cycle ignition and hey presto!!!
Old Mar 20, 2008 | 06:24 AM
earl08's Avatar
thanks fjt, I'll try that before I take it in.
One question... where is the BTUM???
thanks
Old Mar 20, 2008 | 06:54 PM
Under the center console. Remove cup holder. You will see a 20 torx screw under there. It just pulls up....2 piecces. Then inside arm rest box you will see another one rearward toward drivers side. Remove them. Next open ashtray, pull wood up from around shifter. Then the trim under the wood that goes around radio etc, pull that up and back starting at rear and remove. Be careful not to scratch wood. Now pull armrest box up and you will see a little black module there about half the size of a pack of cigarettes. Follow the harness to back of console and unplug it.
Old Mar 24, 2008 | 05:40 AM
earl08's Avatar
Well since its warranty I took it to the dealer. They kept it all day Friday only to tell me so far they have no idea what is causing the problem. They said dealer tech support was closed and would reopen monday.
guess we'll see monday.
thanks
Old Mar 24, 2008 | 05:11 PM
jag_genius's Avatar
lol ..
Old Mar 24, 2008 | 08:12 PM
Is it a small dealer? They should know how to fix bluetooth problems.
Old Mar 25, 2008 | 06:13 AM
earl08's Avatar
a new module was ordered yesterday. It should be here tomorrow.
let's see how this goes.
Old Mar 25, 2008 | 06:09 PM
$50 says it was the BTUM.
Old Mar 27, 2008 | 04:08 AM
earl08's Avatar
Jag_genius Cash or a check with 2 ids is ok. turns out it was the BT antenna
must be a small dealer. they had to order one of course. Tomorrow.
Old Mar 27, 2008 | 06:22 PM
Wow....never seen that yet.
Old Mar 27, 2008 | 07:13 PM
jag_genius's Avatar
huh? and to add the bluetooth antenna is the bluetooth module.
Old Mar 28, 2008 | 07:36 AM
earl08's Avatar
they tell me (the dealer) that the BTM is in the trunk and the antenna module is in the center console. did jaguar move the btm from the center console?
Old Mar 28, 2008 | 07:44 AM
The BTUM incorporates the antenna. It is under center console. The module in the trunk is the PSE module that communicated everything to the audio unit. Also stores your phone book.
Old Aug 30, 2011 | 08:59 PM
Jag_man81's Avatar
Default Btum
So if I add a BTUM antenna, does that mean I will have bluetooth capabilities in my car with my iphone?
Old Aug 31, 2011 | 01:48 AM
JagV8's Avatar
You'll need the BT module, microphone and whatever as well. There are threads about this - here or the X-Type forum so just follow them
There's also help on jag's site if you look (google if not instantly obvious).
Old Aug 31, 2011 | 06:30 AM
JOsworth's Avatar
Nope... Need Bluetooth Module, Phone Module, and the microphone and accompanied wire harness sections....
The components (last time someone quoted) were around $1,500.
Since then prices may be less... Try lookin for used components???
