Bluetooth Hack via CD port 2001 S-Type? Anyone??
Old May 12, 2023 | 06:57 AM
bschroder's Avatar
Default Bluetooth Hack via CD port 2001 S-Type? Anyone??
Hi everyone. So I purchased a beautiful 2001 S-Type. The Multi CD changer in the trunk is jammed, and won't work. Does anyone have a bluetooth adapter (link hopefully)that I can plug into the back of the stereo, which I can then connect my phone to? I currently have a small XM adapter that was already in the car and went through FM, but this runs into way too many issues. Thank you for any advice, as I would rather keep the original radio, and just run bluetooth from my iphone 13 if possible. Thanks for any suggestions.
Old May 12, 2023 | 06:52 PM
Aarcuda's Avatar
Not sure its possible. I know it’s not easy. Definitely not as easy as hooking something up to a port that’s already existing. There are several posts on here about adding Bluetooth and they all require extensive electronic replacement
Old May 13, 2023 | 02:27 AM
Rober2's Avatar
here you are. I have something similar but older model. it needs your cig lighter. the idea is, this dev is an FM transmitter with bluetooth, so you find a blank FM channel on your radio, set the FM channel of the dev to match, find the bluetooth dev from your phone (mine reads car-kit) and Bob's your uncle. No messing around with radio.
Old May 13, 2023 | 08:32 AM
kr98664's Avatar
I would rather keep the original radio, and just run bluetooth from my iphone 13 if possible...
Look at the Isimple ISFM2381. You install this device behind the stock radio. Your phone connects to it via Bluetooth. The device plugs inline to the radio antenna connection. When listening to music from your phone via Bluetooth, the device takes over the antenna input on your stock radio. When listening to the radio, the connection automatically switches back to the stock antenna.
Isimple ISFM2381
One question for you, though. Have you tried listening to music via Bluetooth? I previously had an earlier model in my car. I'm no audiophile, but was not impressed with the sound quality via Bluetooth. From what I understand, Bluetooth was never designed for transmitting audio, and it showed. I eventually swapped it for a different model (IS7705) that uses a Lightning cable to physically connect to my iPhone. The sound quality is much better, and it charges the phone at the same time. This link shows what I still have, but unfortunately it has been discontinued:
https://isimple.com/products/univers...ning-connector
Old May 13, 2023 | 09:20 AM
scrannel's Avatar
Jaguar AUX / Bluetooth (jagaux.com)
Apparently, they now also have a version for the Alpine Radio. They told me in an email they were about to come out with a new version.
Also Jaguar Audio Solutions (jagbt.com)
Old May 14, 2023 | 04:59 AM
elDariusVargas's Avatar
I did connect a 5.0 bt qualcomm chip instead of my cd reader. JagDroid website has the instructions. The chip i got from the internet here
Old May 23, 2023 | 05:02 PM
scrannel's Avatar
JagDroid is also able to upgrade our "old" navigation to a more current version. They can add BT to your CD/Radio or do that and upgrade the Nav. But if you want to stream OTA you'd have to setup your phone as a hotspot and connect to the new device over Wi-Fi or through an aux-in. The new device can't go OTA. I might give it a try.
prodigy215
May 4, 2020 03:05 PM
YYC guy
May 24, 2016 10:32 AM
greenshadow
Apr 9, 2014 04:49 PM
rsgensburg
Dec 16, 2013 03:20 AM
Winks
Dec 2, 2012 02:20 PM
