Brakes not function properly.. Sensor maybe?? Help asap
Old Feb 21, 2012 | 10:16 PM
prodigy215's Avatar
Exclamation Brakes not function properly.. Sensor maybe?? Help asap
My Brake Master Cylinder had got change recently because the brake pedal went all the way down to the floor when i holded brakes, which fix my braking distance. But my brakes are fully not back to normal (i have to hold the brake pedal all down for brakes to perform properly, whereas i use to just tap the brakes and the car would be ready to stop).
Problem: In my dash it says "Brake Fluid Low", but the brake fluid is full. Is this a failure of the Brake Reservoir Sensor that needs to be replaced?? P.S: When i hold brakes there is a hesitation in the car wanting to stop or slow down unless i hit the brakes hard, can the sensor cause this problem or its another issue? It would be great if i can get this problem fix asap, Thanks
Old Feb 22, 2012 | 02:49 AM
JagV8's Avatar
Hesitation may point to a vacuum leak. Need to fix that if so.
Old Feb 22, 2012 | 06:53 AM
police666's Avatar
also check the system has been "bled"(all the air removed).
Old Feb 22, 2012 | 07:19 AM
joycesjag's Avatar
All great advise above!
Also how worn are the pads?
Old Feb 22, 2012 | 05:32 PM
prodigy215's Avatar
Exclamation
Thanks alot for the reply guys. Does the Brake Reservoir come with the "Brake fluid level sensor" inside of it?? If not, Where is the Brake Fluid Level Sensor located? thanks
Razor
Aug 28, 2019 08:34 PM
PMKimpton
Aug 3, 2019 08:22 PM
Aus V8S
Nov 13, 2015 11:01 AM
KarimPA
Sep 12, 2015 08:15 AM
tberg
Sep 7, 2015 07:32 AM
