Broken Rod
Old Jan 31, 2011 | 06:13 PM
noodlearm's Avatar
Hi George, yes I have full power to everything. I believe (again I know very little about car mechanics so my brother-in-law has been helping me out a little) the dealer told him that they couldnt get the engine to spin forward at all. I am not exactly certain on the terms they used by I will check with him.
Old Jan 31, 2011 | 06:25 PM
Staatsof's Avatar
All kidding aside. Go somewhere else and get another opinion. You'd probably do it for a medical situation, this is no different.
Keep your spirits up and the best of luck to you.
Old Jan 31, 2011 | 06:29 PM
androulakis's Avatar
Rods don't crack with no outward indication. You don't park your car at night with it perfectly and come out in the morning to a seized motor. It's a catastrophic failure.
Have someone else have a look at it. Does the starter even attempt to engage?
(I'm assuming you don't have the car in your possession at the moment and you don't have tools to test it by your disclaimer of not being mechanical in nature).
Take care and keep us posted.
George
Old Jan 31, 2011 | 07:50 PM
bfsgross's Avatar
noodlearm, George could'nt have laid it out clearer...it your STR ran smooth and quiet before shuttin her down the night before then look elsewhere besides engine failure. Mind you that an STR can consume a quart of oil every 4k miles.
Old Jan 31, 2011 | 09:15 PM
Really? Must be the oil feed into the supercharger. They don't smoke or leak, and they can get trough emissions so they aren't burning it or fouling out plugs.
What's the oil capacity on an STR anyway?
I still think he would have had a motor that sounded like a diesel tractor on a cold day, and would have gotten oil pressure warnings etc if the motor was starved for oil.
Oil starvation also tends to spin bearings or score cranks before it breaks rods.
Breaking rods is usually due to leaning out... Both of the times I broke a rod in my IROC were on the spray.
Take care,
George
Old Jan 31, 2011 | 09:43 PM
vance580's Avatar
My STR takes just shy of 7.5 quarts. I think the supercharger has its own oil and doesnt run off the oil from the engine. I think there was a post about how to change it a few months ago.
You would have alot of warning that you were starving it of oil. Like everyone said you would hear something is not right if you were running it with no oil or have blown a rod.
Old Jan 31, 2011 | 10:04 PM
Oh so it's like a paxton supercharger.. Gotcha.
Yeah I know starving it for oil wouldn't be pretty or unnoticed. I'm just speculating as to where the oil goes as per BFG's post. I had a Mercedes a while back that would eat a quart of oil in 1k miles, had bad valve guide seals, but it never smoked or failed an emissions test.
Take care,
George
Old Jan 31, 2011 | 10:40 PM
  #28
vance580's Avatar
Take care,
George
I guess it depends on the engine. Mine only burns up about .5 qt between oil changes which I change it around 5-6000 miles. I never have had smoke or failed emissions. I also always let the car warm up before it leaves its parking spot which probably helps some. Probably depends on temp and how hard you get on it. When it was hotter out and I was on it more it did burn a little more. Now that its colder I drive it pretty easy.
Old Feb 1, 2011 | 02:22 AM
JagV8's Avatar
Over here we're told NOT to warm cars up that way (well, 10-30 secs but they're not warm by then!).
Old Feb 1, 2011 | 06:32 AM
  #30
vance580's Avatar
I always thought that was good for it. I usually start up the car to get the inside temp to a comfortable level while I take the dog out, then just hop in and go. So it usually gets about a 5 minute warm up before I leave anywhere. If thats not good I'll have to stop doing it. Now that I have a garage it isnt a big deal like it was before.
Old Feb 1, 2011 | 06:36 AM
  #31
bfsgross's Avatar
My STR burns only a little oil too. Some here have expressed concern when learning their 4.2 was down a quart or so when oil was dropped for a swap. My 2nd hand 98 Mustang Cobra (previous owner raced it at Lime Rock, CT.) burnt a quart every 3k. I didn't feel this was normal so elected to sell her.
Old Feb 1, 2011 | 07:16 AM
  #32
Gus's Avatar
Gus
Are you sure you have oil in the car? When was it last changed, who did it and what oil did they use. It sounds more like it is seized.
Old Feb 1, 2011 | 11:54 AM
  #33
noodlearm's Avatar
I had my last oil change at 100k and am currently at 104K, have always had the changes done at the dealership with the recommended oil. I don't think the issue is with the oil, no light ever came on and I never saw any leaking in my driveway or were it broke down. Like I mentioned, I do plan to take it someplace else to have it checked out. I will keep you all updated, and thanks for the help.
Old Feb 1, 2011 | 12:34 PM
  #34
Gus's Avatar
Gus
Keep in mind that the light is not an oil level indicator, it is pressure only. The oil level indicators came out on Jags I think 2010 on one or two models I think. When it would not start did it sound like the starter engaged but the engine would not turnover?
Old Feb 1, 2011 | 01:39 PM
  #35
vance580's Avatar
Yea I think I've pin pointed my oil loss to the crappy oil filter that I used. I ended up getting a Purolator PureONE which is supposed to be there high end oil filter. Its also the only kind I can get locally. Well the seal on them doesnt seat when you have the filter all the way tightend so it has a very very minimal drip so not gonna use there crappy filters anymore. Probably gonna try someone else since now I will have to order it online now.
Old Feb 1, 2011 | 01:54 PM
  #36
tbird6's Avatar
Yes the super charger oil is separate from the engine oil. Change it around 60K miles or so. You can use Ford or GM oil or even Turbine oil.
It's NOT a Paxton it's an Eaton super charger. M112 which means the supercharger has a capacity of 112 cubic inches.
Old Feb 1, 2011 | 01:59 PM
  #37
It's LIKE a paxton in that it has it's own self enclosed oil supply. Paxtons were designed to be remote mounted.
I'm surprised they didn't use a Bigger blower than the Eaton M112. What do those things run for boost stock anyway?
Take care,
George
Old Feb 1, 2011 | 02:02 PM
  #38
JagV8's Avatar
Is there room for bigger?
(Recall avos uses a TS for more boost)
Old Feb 1, 2011 | 02:07 PM
  #39
Staatsof's Avatar
Wix makes one for the car (STR) and those ARE good filters. Maybe they even make Ford's version of this filter? You can buy a case at something of a discount.
Old Feb 1, 2011 | 02:09 PM
  #40
The m112 is the biggest supercharger eaton makes..... But it's a fairly poor, but cheap choice (from a performance potential perspective).
It displaces 112 cubic inches or 1.835l per rotation.
The Mercedes AMG Cars all use a whipple twin screw supercharger setup
http://www.whipplesuperchargers.com/...sp?ProdID=1162
Notice the Biggest Eaton barely out displaces the smallest twin screw?
With an M112, you're almost at max compressor efficiency in a stock setup. There's only room for 2-3 extra PSI of boost.
With a similar physical size Twin screw you can run 20+ lbs of boost
Take care,
George
