broken shifter box
Old May 1, 2016 | 01:58 PM
croppy's Avatar
Default broken shifter box
My 2000 S-type has not been shifting into neutral, got the common suggestions of stretched cable, checking the two bolts (was informed that was for the later models though). After i removed the center console, I had noticed that the box the shifter goes into is broken on one side. When I try to shift it to park the side with the break bows out a lot and it seems like it doesn't provide the leverage for the the shifter to move the mechanism any further forward. So intil I can get the parts needed (that box and new cable) is there any way to make it so the battery doesn't die every time I park the car for a few hours? Can't get the gear shifter in park so can't get the key out. Thanks
Old May 1, 2016 | 02:21 PM
JagV8's Avatar
You could disconnect the battery
Not ideal but better than flat.
Or maybe hunt through the electrical guide for fuse(s)/relay(s) to remove.
Old May 1, 2016 | 02:45 PM
croppy's Avatar
and more importantly, does anyone know where I could fond said box...cheaply
Old May 1, 2016 | 03:27 PM
JagV8's Avatar
A wrecker / ebay / ...
Old May 8, 2016 | 08:39 PM
croppy's Avatar
Thanks for the help, got the new gear shifter and put it in. I can now shift to park (hooray) and take the keys out (hooray). However, now when I go to start it, it just shuts down. It works with the key in the accessory position but when I actually try to crank the engine it just cuts power to everything. Could this be a result of the battery being dead (using a jumper box) and needing a good charge or it something worse?
Old May 9, 2016 | 12:07 AM
Datsports's Avatar
test your battery it sounds to be dead! also check your battery terminals are secure.
hm1
Apr 5, 2016 08:49 AM
hisport
Apr 3, 2016 07:34 PM
the_georgester
Apr 3, 2016 05:46 PM
Ksnowcut
Apr 2, 2016 02:43 PM
MarkC123
Apr 2, 2016 07:51 AM
