Broken Speedometer
Old Feb 4, 2008 | 07:14 PM
FactoryJaguarTech's Avatar
Default RE: Broken Speedometer
You definitley do not need to remove steering wheel.
Have you tried disconnecting battery? When we recieve new instrument packs they are normally pegged like that, but once power put back to them they reset.
Give it a try before you start to tear things apart.
Old Feb 5, 2008 | 01:18 PM
You have to pull the side vents out first, then the wood. After that you will have access to the pack.
Do you have wiring diagram?
Old Feb 5, 2008 | 05:55 PM
H20boy's Avatar
My Jeep did this more than once, and I can't remember how I reset the gauge. It kept occcuring when the battery terminal was shorting, and it would peg the speedometer/tach gauges, but the speedometer would often get stuck there.
I think, with the key turned to the accessory position (no ignition), I disconnected the battery again...reconnected, and it 'cycled' from 0-max on each gauge. The speedometer would catch this time, and fall back with the tachometer. Couldn't hurt to try...
Old Feb 5, 2008 | 06:26 PM
Also, before you dismantle the pack, try tipping it sideways to get the needle to drop the other way, then reconnect. May just be a glitch. The wiring diagram is important.
When you get to that point, I will give you wires to check. See if a signal is being sent to pack to say "Hi I am doing 160 mph!!!"
Old Feb 7, 2008 | 03:04 PM
Glad we could help.
MrWhite
33
Oct 22, 2015 10:29 AM
King Charles
Oct 16, 2015 01:25 AM
adam699
Oct 13, 2015 05:53 PM
inactualis
Oct 2, 2015 11:13 AM
