buying a 2003 s type-r
Old Apr 13, 2011 | 06:38 PM
bdmpit's Avatar
Default buying a 2003 s type-r
hi i'm new here and looking for some advice. lookin at a 03 s type-r with 83k miles. dont know much about jags and any info in what to look for or any pros or cons of this model would be helpfull. there asking $10000
Old Apr 13, 2011 | 07:50 PM
phd12volt's Avatar
somewhere around here there is a thread exactly about the 2003 str.
I know for a fact look at the thermostat to be sure it has been replaced.
I suffered from a bad torque converter, and headlight motors. Also check the rear shocks for leakage. Look insider the trunk and look under the spare tire for signs of water being trapped in there too. and the more you search the more will be added.
Old Apr 13, 2011 | 08:25 PM
bfsgross's Avatar
Have the same STR as PHD12volt. Bought my silver 03 87k STR last May for $11,500. Love it. You may have a great deal for $10k. Check her CarFax and have competent mechanic check her over.
Old Apr 14, 2011 | 02:52 AM
JagV8's Avatar
Not much really to worry about - except as with any car purchase you could be unlucky. Check the things you'd check with any car (tires, brakes, suspension, past damage, etc).
That's such a low price for a stunning car that you should check very carefully and if it's even reasonably OK then grab it quick! Budget to spend some $$$ because at that price something seems likely to need doing. Plan to change engine oil, brake fluid, engine coolant - and use the right fluids. Also change air filter, pollen filter, fuel filter. Check/change drive belts (aux & SC). Just use jag parts at this stage since if any problem comes up you don't want to be wondering as to the cause.
If the battery's not especially new, plan to change it. Trust me on that. You want a solid baseline.
If you can DIY then do so
(and get the workshop manual - topic you'll find during reading here)
Read the forum (big job!) and have fun!!
Old Apr 14, 2011 | 08:35 AM
qikcat's Avatar
All good info here from someone else who is looking at a STR as well.
I have also read all the timing chain/tensioner threads in my research. I know its all relative and the timing components could go at varied miles but at what mileage would you guys think that if there is no paper work that the timing system has been replaced you need to figure doing it upon purchase?
I plan unless recent service records to change drive belts to include SC. all new fluids and filters and check trans at the dealer, tune up, ecu tcu reflash, check brakes and alignment.
Old Apr 14, 2011 | 08:38 AM
qikcat's Avatar
OOOps posted before I was done. Any other things STR specific I should figure into my purchase price beyond those mentioned above?
Old Apr 14, 2011 | 09:08 AM
Jayt2's Avatar
Veteran: Navy
Active Streak: 30 Days
I definitely second that, trust me also on that one...
I have a neighbor who also has an S-Type ( a couple of years older than mine) and he replaces the battery about every three years regardless.
Old Apr 14, 2011 | 09:24 AM
phd12volt's Avatar
https://www.jaguarforums.com/forum/s...-type-r-36578/
Old Apr 14, 2011 | 09:37 AM
PhilT's Avatar
Default 03 str
I bought a 03 STR a few days ago with 80k, paid $10.5 for it. had three (?) new tires but later found one of the wheels had been patch welded. AllFactory had one of these rare wheels for about $400. The belly pan was probably torn away but no damage to the undercarriarge. Anyone suggest where I can find one?
Will replace the odd tire, replace rotors and pads all round in the next few days. Local Jag expert will reflash the transmission module and drive belts New DieHard or Interstate battery shortly and am willing to go through the reprograming of the parking brake, windows, pedals etc,.. The headlamp self leveling system had failed but see thread in the JagForum on an inexpensive fix.
The car was lowered and am considering returning to orginal springs. It handles well enough and a bit more civil ride would accommodate my wife. Maybe a 4.2 standard S type is more our style.
Phil in Tenn
03 STR (very green)
05 Mazdaspeed Miata
73 Lotus Elan +2 show and go car ( for sale)
a couple of drivers
Old Apr 14, 2011 | 10:09 AM
JagV8's Avatar
Congrats!
"very green" - which one? Code(s) on label by door hinge (er, passenger side here, don't know over there). E.g. HGZ is jag racing green.
Old Apr 14, 2011 | 11:20 AM
The Chris X's Avatar
Congrat's X2!
Enjoy, sounds like you have formulated a good plan to get her up to snuff in short order.
Undertray - perhaps try Motorcars LTD, they may have a used one on hand.
Old Apr 14, 2011 | 11:58 AM
bfsgross's Avatar
Congrats Phil and welcome to STR land.
Old Apr 14, 2011 | 05:55 PM
bdmpit's Avatar
i think my thread has been hijacked lol
Old Apr 14, 2011 | 06:03 PM
JagV8's Avatar
haha, yes! Though maybe we were expecting your follow up would be "I bought it"
Old Apr 14, 2011 | 06:16 PM
bdmpit's Avatar
kinda gunshy,,,cost of repairs kinda scare me..are these cars something a regular repair shop cant work on?
Old Apr 14, 2011 | 06:25 PM
vance580's Avatar
Depends on the repair. Your best bet is to try and find a reputable mechanic that knows what he is doing and you should be good. The problem lies is finding him. Maybe call around just to ask if they know Jaguars. Euro places will obviously be your best bets. If they give you a hard time just asking their expertise on Jags then they just helped you determine they probably arent the shop for you.
If Hornell means Hornell, NY there seems to be alot of Jag owners up in the PA, NY area maybe post in the regional section looking for some shops then give them a call and get some info on their expertise.
Also if you do get it check out the sticky on the meet in PA in June.
Old Apr 15, 2011 | 03:25 AM
Cadillac's Avatar
Congrats Phil , have many safe driving
bdmpit, if you pull the trigger for it I hope you will be happy with your ride as well
Old Apr 19, 2011 | 06:22 PM
bdmpit's Avatar
well i went ahead and bought it. paid $9400..i'd post some pics but cant figure out how????
Old Apr 20, 2011 | 04:06 AM
Cadillac's Avatar
This is the link to your questions , check in FAQs
Jaguar Forums Help & Suggestion Center - Jaguar Forums - Jaguar Enthusiasts Forum
Bear in mind , being a new member you may not upload pics from your own computer unless you are granted full access by admins
Old Apr 20, 2011 | 05:55 AM
bfsgross's Avatar
Way to go Phil! We're happy to hang with ya. Come to the Jaguar "S" meet in June.
ccismobile
Sep 14, 2015 07:48 PM
Ipc838
Sep 13, 2015 03:27 PM
kabs3012
Sep 12, 2015 10:40 AM
kabs3012
US Midwest
Sep 10, 2015 01:17 PM
David Thompson
Sep 3, 2015 07:48 PM
