A/C issue for 2003 S-Type
Old Jul 4, 2009 | 10:22 PM
Thermo's Avatar
Veteran: Navy
Paula, our vehicles maintain the temp for you. So, when you have the ventilation system running normally, the A/C system runs all the time to dry out the air. This causes the incoming air to be colder than you are wanting. So, this forces the system to run the heat a little bit to warm the air back up to what you want. This is normal for the vehicle. if you are not wanting the air dried, then you can normally turn off the A/C manually, which should also prevent the heat from running too. But, keep in mind that if the air temp rises, the system will not be able to cool the air. So, this would involve you turning the A/C back on manually.
have fun in Mill Creek. I loved that area. Used to live in Bremerton and ended up in Mill Creek all the time.
Shawn Svacha
Nov 4, 2019 02:47 PM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
jehart49
Sep 12, 2015 05:36 PM
user 652867429824
Sep 5, 2015 12:53 PM
OkieTim
Sep 2, 2015 12:48 PM
