A/C stopped working
Old Aug 29, 2011 | 08:27 PM
jeffzm's Avatar
Default A/C stopped working
Great timing 107 in so cal. heat wave and a/c just quits. First time to the dealer since i have owned it, so time for service too. ballpark estimate on a/c 2 g's (have 4 years left on a warr.) good thing. So what else while at dealership ? car has 42,000 miles on it and I think the rear struts might be bad cause of some slight knocking in rear. Also the typical lurching which has been getting worse and have read some threads on it as far as re mapping.
Anything else for a 06-STR that I should have checked out really want an exaust and H&R springs
Old Sep 1, 2011 | 11:28 PM
jeffzm's Avatar
approx. $2,200 for repairs to a/c, extended warr. is covering it Whew!! They say also front brakes are needed approx. $600.00 I said no gotta do some shoppin, jerky starts they need to re program at about $400.00 ? and front tires Not at dealer.
Input on local shop ?
Thx, Jeff
Old Sep 2, 2011 | 07:44 AM
The Chris X's Avatar
You'd think the tranny issues would be warranty work. Are they not?
Do brakes yourself - Vance580 has a DIY Youtube video and there is a ton of info on here how to do it. Very easy job.
Tires - i do Tire Rack or Discount Tire Direct these days. No need to pay the dealer markup.
If your struts are shot that seems like it is a premature failure. I'd check your bushings and such. Can you describe the knocking a bit more?
Old Sep 2, 2011 | 09:30 AM
bfsgross's Avatar
Worn rear control arm bushings cause knocking?
Old Sep 2, 2011 | 10:52 AM
JagV8's Avatar
$400 for reflash - no way! More like $150. Granted they need to do both PCM & TCM then drive it with 2 people, hooked up to IDS, but $400 is too much.
Old Sep 2, 2011 | 11:08 AM
My dealer reflashed the TCM in my X-type for free as a courtesy when it was in for something else, this was while it was under 3rd party warranty. If they value your business and satisfaction, they should at the very least cut you a steep discount. It can't take 3-4 hours of shop time to do that flash....
Old Sep 3, 2011 | 09:15 AM
jeffzm's Avatar
Looks like its time to search for an independent shop in Corona/Riverside area.
thanks all for the input.
Jeff
Old Sep 3, 2011 | 09:36 AM
Jayt2's Avatar
Veteran: Navy
Active Streak: 30 Days
There's one in Upland, but he might be a tad too far away for you.
tberg
Sep 7, 2015 07:32 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 07:47 PM
Sep 3, 2015 12:21 PM
OkieTim
Sep 2, 2015 12:48 PM
XJsc-guy
Sep 2, 2015 11:43 AM
