Camshaft position sensor
Old Feb 10, 2017 | 07:31 AM
phildog's Avatar
Default Camshaft position sensor
Hi all just purchased s type r diesel
And have restricted performance.
Would like to check camshaft position sensor but have no idea where it's located,
Idiot proof instructions would be appreciated thanks in advance phildog.
Old Feb 10, 2017 | 10:12 AM
bydand's Avatar
Phildog,
Its on page 1160 of the S type workshop manual.
I suggest you download it, Gus has a downloadable copy from his website.
see jagrepair.com
If not it is only going to lead to more questions, and the manual provides lots of answers.
Good luck
I assume the S type R diesel, R being for restricted.
Old Feb 10, 2017 | 10:32 AM
MyBlackCat's Avatar
S type R diesel ???? Wow. never knew they made them. Please post some photos.
Old Feb 10, 2017 | 11:30 AM
phildog's Avatar
Default My mistake
i believe it's a 2.7 diesel s but I could be wrong anyway it's a lovely car but drives like a pig all for a 10 min job and a 15 pound sensor would you mind telling me how I can get in touch with gus so I can arrange to ask him if he would make workshop manual available to me. Have seen in other threads that there is a how to on this, how do I access the how to section have tried to search but unsuccessful. Thank you.
Old Feb 10, 2017 | 11:39 AM
Welcome to the forum phildog, "the how to" section is at the top of the page https://www.jaguarforums.com/forum/s...-guides-41364/ you can also download JTIS from here https://www.jaguarforums.com/forum/s...archive-66031/ you will find Gus's site here JagRepair.com - Jaguar Repair Information Resource
The new members section is here New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum we always like to see an intro from new members.
Old Feb 10, 2017 | 12:05 PM
phildog's Avatar
Ok have looked on the gus website can't find find work shop manual or any thing that would point me in the right direction. Thanks to anyone who tried to help I'm obviously to stupid to navigate round this site, I shall look elsewhere if anyone knows where the camshaft position sensor is located I would be grateful if you would tell me will check tomorrow for any ans to this then log out and give up thanks for trying. Cheers.
Old Feb 10, 2017 | 12:26 PM
MyBlackCat's Avatar
phildog. not trying to send you away but maybe try the UK jag forum
This forum has very few members who own diesel Jags. most of the members are from countries that never sold diesel S types.
Old Feb 10, 2017 | 12:49 PM
phildog's Avatar
Will try there thank-you
Old Feb 11, 2017 | 01:34 PM
Don B's Avatar
Hi phildog,
Welcome to the Jaguar Forums.
Out of curiosity, what has prompted you to want to check the camshaft position sensor (CMP)? Did you have the car scanned for stored diagnostic trouble codes (DTCs) that pointed you to the CMP?
Other than determining whether the CMP has somehow become disconnected, there is little you could determine by a visual inspection. By the way, if the cylinders in your engine are oriented in a V formation, your engine may have two CMPs.
I would recommend that you have the DTCs scanned by a shop with the equipment necessary to read the proprietary Jaguar fault codes and not only the generic OBDII codes. Carefully write down all the codes, including their initial letter (P, B, C or U) and post them here and at the U.K. forum as MyBlackCat recommended. We'll try to help, and I'm sure some of the U.K. members will do likewise.
Cheers,
Don
Old Feb 12, 2017 | 09:12 AM
phildog's Avatar
Originally Posted by Don B
Hi phildog,
Other than determining whether the CMP has somehow become disconnected, there is little you could determine by a visual inspection. By the way, if your the cylinders in your engine are oriented in a V formation, your engine may have two CMPs.
Cheers,
Don
car was scanned in garage and it was Crankshaft not camshaft low signal and EGR insufficient flow going to take off EGRs and clean make sure electrical contacts are clean if so replace.. Have had lots of help from UK site asked same question on there as here got ans diagrams and advice straight away just waiting for a break in the weather and will get it sorted. Also have dpf full on screen so will take this off and have a look as it's only 6 months old will check sensor first see if it's operational. Thanks for your reply.
Cheers Phil.
Old Feb 12, 2017 | 03:59 PM
Ducmon's Avatar
If you are getting dpf full check your oil level as you may have diesel in it and if you drive the car you will seize the engine. If you are not sure change the oil.
Old Feb 13, 2017 | 03:52 AM
phildog's Avatar
Default Dpf full
Oil has just been changed and level seems constant and there is no brown gunk around filler cap, dpf is only 6 months old so will take off and have a look it may just be sensor, there is a company close to me that will clean with high pressure water am considering this as it's cheaper than a new one. Thanks for your response. And advice.
Old Feb 13, 2017 | 04:21 AM
Ducmon's Avatar
No problem I just thought that you may not know about this problem.
Old Feb 14, 2017 | 04:08 AM
phildog's Avatar
Thank you anyway would much rather get told something I already know than someone not tell me and I blow my engine up :-D
