Car dosent liek hills and im moving where there are nothing but hills please help
Old 06-25-2010, 01:35 PM
Stype4life's Avatar
Default Car dosent liek hills and im moving where there are nothing but hills please help
Hey all, Im new here. Im having issues with my Car here and need to bring them to an conclusion as I decided to not sell it.
When Im going up hills my car jumps and stutters. When I take my foot off the and then gas it again it catches gear and is fine. It also happens when its not shifting and theres no need to find a gear but removing foot off gas and reapplying always works. The Ticking is annoying and use to do this until the transmission ultimately died, I hope this isnt the issue again. No gear Box default code appeared like last time. I am moving to California where their are plenty of Hills to fustrate myself and my S-Type.
When I make a sharp right turn, as far as the steering will allow the car stops. If I gas it will putter maybe but wont go anywere until I straighten the wheel out. This is a new one for me.
The 02 sensor code pops up daily. Even after I replace the one that was supose to be bad. I think I have replaced multiple times. Jag dosent know why its like that but it would be nice to see if any of you here have dealt with any of the issues so that I can be at peace with my car finally.
I appreciate anybody who will come to aid thanks all
Old 06-25-2010, 01:37 PM
Stype4life's Avatar
Sorry forgot to mention it is a 2000 S-Type which I think have been in an accident passenger door. The dealer hid this from me and painted the car im sure of because the paint came off 2 years later and im painting it now. I know now to never by a car from some bums that have a dealership again, if it didnt come from Jaguar then you wont get the best service
H20boy's Avatar
Received 1,149 Likes on 753 Posts
year, and engine size please, or else you won't get much advice, or much conflicting ones
edit - beat me to my question, but what engine size, 4.0?
Old 06-25-2010, 01:48 PM
Stype4life's Avatar
Thanks mod forgot that too
its a 3.0 6 cyl
2000 model
Old 06-25-2010, 03:00 PM
Stype4life's Avatar
Alot of reports say the 4.0 has that jumping or ticking situation going on uphill but, my 3.0 has been having that issue too often
Old 06-25-2010, 08:52 PM
H20boy's Avatar
Sorry don't know much about the 3.0s, so will have to belay to others on here. give it a day or two for more help, ok?
Old 06-25-2010, 10:39 PM
Oldengineer's Avatar
Default Has the fuel ever been changed??
The fuel filter may be about plugged up. Has it ever been changed??
Regards:
Oldengineer
Old 06-26-2010, 10:28 AM
Stype4life's Avatar
Regards:
Oldengineer
No but ill get on the job. Which problem will this resolve?
Are you aware of any good fuel filters for the car I can go with jaguar but they dont make the best parts sometimes
Old 06-26-2010, 10:42 AM
JagV8's Avatar
Received 4,507 Likes on 3,919 Posts
Unless you know a lot about cars, just use jag parts for these common things as they're not badly priced.
Old 06-26-2010, 10:49 AM
H20boy's Avatar
any fuel filter Stpe, there's been no controversy one over another... thank goodness
Old 06-26-2010, 01:41 PM
Stype4life's Avatar
Thank you all for the info I will get the fram fuel filter see how that works and come back it has over 100k on it maybe time for a tuneup aswell? dont know how much that costs yet.
Old 06-27-2010, 03:08 AM
Cadillac's Avatar
Please wait until an expert to shed a light on this . I would go for OEM but WIX also a good brand if you pick up an aftermarket brand . I have read most comments just as " do use anything but FRAM "
Old 06-27-2010, 09:22 AM
JagV8's Avatar
The time to avoid aftermarket parts is when you already have a problem. Or when you're changing multiple things at the same time. E.g. don't put aftermarket plugs or coils on a car that's got engine problems already.
When you DIY you save plenty. Why take risks with the parts, especially when you have existing faults???
You'll likely fit only one fuel filter in the years you have the car. Why "save" a few $$$ on one that may not work properly? They're cheap anyway.
Old 06-28-2010, 09:54 AM
Stype4life's Avatar
ok Mod I will wait for an expert opinion on this.
I do have a question I see someone said use anything but fram I worked at pep boys and fram was our top line oil filter should I be using jaguars brand?
Old 06-28-2010, 01:50 PM
tbird6's Avatar
I used to use Fram but WIX has a much better reputation. There are some good filter comparisons on line that show the WIX is better constructed. I will say that simply changing the filter is MUCH more important than the brand of the filter!!
Old 06-29-2010, 10:43 PM
bfsgross's Avatar
Yep, fuel filter or pump. Either is an easy swap.
Old 06-29-2010, 11:03 PM
statue22's Avatar
Have you check the transm.
Old 06-30-2010, 03:12 AM
jagmadjohn's Avatar
You say you have a ticking noise have you a hissing noise a the V6 does suffer from vacuum air leaks
btw Welcome
Old 06-30-2010, 12:17 PM
Stype4life's Avatar
Thanks all I spoke with jag today they said I need a Tune-up $1200 I cant afford being that its being painted so I will try to get a trusty mechanic on it.
I forget all that they say is needed, I know he said I need coils which is the reason for the issues
coils,fuel filter, air filter, plugs and there was something else he said I need but I cant remember for the tune up any help?
Old 06-30-2010, 12:20 PM
Stype4life's Avatar
no but I will
btw Welcome
there is no hissing noise fortunately however I did forget to ask why the car loses power when turning maybe coils???
Quick Reply: Car dosent liek hills and im moving where there are nothing but hills please help
