Car will not start
Old Jun 10, 2010 | 03:02 PM
juans_jag's Avatar
Exclamation Car will not start
Hello to all .... In the morning or when my 01 jaguar Stype is cool I nearly have to turn the key 3 times before it can turn on .. example if i stop some where come back in about 40 mins same thing have to try and crank it about 3 times before it can come on... Any ideas or help would be helpfull.. Thankss..
Old Jun 10, 2010 | 03:30 PM
JagV8's Avatar
Those type problems are very hard to find. If you've plenty of tools, time, car experience etc then google for lots of data. Otherwise find a competent tech.
Old Jun 10, 2010 | 03:38 PM
Enthusiast's Avatar
Transplant a 4.2. Will fix the problem immediately.
Old Jun 10, 2010 | 04:00 PM
juans_jag's Avatar
What is a transplant 4.2?
Old Jun 10, 2010 | 04:07 PM
Gus's Avatar
Gus
Do you know if it is the key cylinder switch on the column that is giving you the problem? Try this next time move the shifter selector from “P” to “N” position and see if it starts.
Old Jun 11, 2010 | 08:17 AM
juans_jag's Avatar
I can hear the starter cranking but...its like its ingecting or sending any fuel...
Any other suggestions?
Old Jun 11, 2010 | 08:27 AM
JagV8's Avatar
I still recommend a competent tech.
Old Jun 11, 2010 | 12:04 PM
Gus's Avatar
Gus
So you are saying that your starter is engaging and turning the engine but the car will not start is that correct? If this is the situation the next time it will not start take the shifter selector and move it from “P” to “N” position and see if the car will start.
Old Jun 14, 2010 | 02:49 AM
zachster's Avatar
I have this same problem intermittently, mostly when the engine is warm. My mechanic has a theory -- we know that I have a bent flex-plate, and he thinks that this occasionally affects the placement of the crank position sensor. You may not have the flex plate problem, but a bad, or off kilter, sensor can cause these types of issues. I don't know all the sensors on the s-type yet, but from a previous car I know that the crank, cam and timing sensors can often be the culprit when it comes to hard or no starting issues.
Old Jun 15, 2010 | 03:25 PM
Gus's Avatar
Gus
Well have the causes been found yet?
Old Jun 28, 2010 | 08:07 PM
Gus's Avatar
Gus
Did you find a cause?
Old Jun 28, 2010 | 10:39 PM
H20boy's Avatar
he drove it into the nearest lake, after taking 3-4 times to get it started and was therefore, late for work.
Old Jun 29, 2010 | 10:39 PM
bfsgross's Avatar
juans-jag, your S-Type has the worn fuel pump blues. It takes three ignition key turn cycles to build up enough fuel pressure ignite her, then she'll run ok...unless you gun her for awhile. No problem...pull up rear seat and swap in a new one. Problem sol-ved.
Old Jun 29, 2010 | 11:36 PM
H20boy's Avatar
where you been for the last 19 days gross? He could have used you at day 2
Old Jun 30, 2010 | 05:27 AM
bfsgross's Avatar
LoL! water boy. I was waiting for jagv8 to take a shot at it...where the heck is he here? LOL!
Old Jun 30, 2010 | 05:28 AM
bfsgross's Avatar
jauns jag replace fuel filter as well.
Old Sep 20, 2010 | 12:11 PM
juans_jag's Avatar
I finally got around to take my car to the mechanic he said that he also needs to change out the fuel sender aswell???...
Can any one shed some light on this ?
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
Jaguila
Sep 5, 2015 06:16 PM
1964Daimler
Sep 2, 2015 11:41 PM
Vector
US Lower Atlantic
Aug 26, 2015 05:36 AM
