Cat bypass. O2 Swenson eliminator’s?
Old Feb 25, 2022 | 01:53 PM
ThumperDumper22's Avatar
Default Cat bypass. O2 Swenson eliminator’s?
I have bypassed the cats on my 4.2 s type
what’s the best way to get proper reading s on my eco with out installing new ones?
Old Feb 27, 2022 | 01:59 PM
clubairth1's Avatar
Community Influencer
Whats an eco?
If you bypass the cats how are going to get the car inspected and pass emissions?
Old Feb 27, 2022 | 07:42 PM
Whats an eco?
ECM* my bad. Auto Correct.
I’m not worried about that. I just want it to run right getting good numbers.
.I’ll send you a pic lol. I figured someone on here has deleted the cats on a 4.2 L….
Old Feb 28, 2022 | 02:03 AM
JagV8's Avatar
It won't run right with what you've done. Back pressure wrong. EGR wrong. Fuelling wrong. Etc.
Old Feb 28, 2022 | 01:41 PM
clubairth1's Avatar
So it's not emissions legal?
Is it just going to be a track car?
You don't find much about removing the cats because it's not done or needed. They newer cats have little to no restriction. If you are not going to dyno the car before and after your mods how will you know if anything improved?
Old Mar 3, 2022 | 03:35 AM
Aarcuda's Avatar
Youll never get the right reading on your ecm. The cats prove some feedback from those o2 sensors. Plus youll have a check engine light forever for cat efficiency and wrong delay when it tests them And those spark plug extender thingies never work for long
Old Mar 3, 2022 | 12:56 PM
joycesjag's Avatar
I use 2 spark plug extender thingies (anti foulers) in conjunction my downstream O2 sensors in my DD a Vortec V8. I was forced into a cat delete, it now has 2 straight pipes for the past 4 years. Our great state does not have emission testing. I now have over 326,000 on original motor and trans, never has ran so strong! Delete was somewhere around 230,000 miles.
I have to run mid grade gas or higher to keep the check engine (MIL) from illuminating. My butt dyno loves it, especially with the vehicle weighing in around 7,000 lbs.
Old Mar 3, 2022 | 11:34 PM
Aarcuda's Avatar
cool that’s probably the only jaguar they work on
Old Mar 5, 2022 | 04:12 PM
xalty's Avatar
you just get a tune for it
untuned cat delete on 4.2 sc picks up a good amount of power, extenders to turn off the light will make it run horrible
Old Mar 27, 2022 | 04:23 PM
Sportston's Avatar
What's a Swenson eliminator? Does it stop you eating ice cream?
If it does, that sounds pretty serious. Would life be worth living?
vega1robert
Feb 28, 2022 08:35 AM
Jagmister
Mar 19, 2017 04:49 PM
64vette
Feb 23, 2016 11:54 AM
giandanielxk8
Jan 6, 2014 02:41 PM
Pumpkinate
Dec 28, 2012 05:59 PM
