CATS SYSTEM FAULT
I took a apart my center console to work on my J-gate because the stick was loose, I manage to fix that and save a 1000 dollars but some how I tripped a code, maybe coincidence or not but what did I do to trip this and how do i clear it, I tried disconnect of battery also tried positive to ground for a couple minutes no go. I had to dissconnect the sport and traction mode but they are both hooked up know
no not yet have to bring it in, I just thought it might have been when i adjusting the jgate i had the car started and the sport and traction buttons were not plugged in because i had the concole out
engine light off now, was a 02 sensor, cats system fault could not be removed from tech at canadian tire, he could not get into it through the scanner, any ideas on how to clear, I have battery un hooked as of now will see if it works.
thanks in advance
thanks in advance
Make sure the 4 shocks are plugged in and in the shock tower you will see a block with two connectors on it. It looks like two of the same sensor, one on its side and one up and down. Those are you accelerometers. Make sure they are plugged in. If you get your engine detailed, it can cause those sensors to go bad. If everything plugged in, you may have to get dealer to scan it.
I had those unplugged when I was getting at my coils and had the car started with those unplugged so maybe it just need to be cleared because all plugged back in code is still there but goes away if you turn the key but dont start it and wait for fuel pump and other stuff to load then start the code dissappears, but if you just get in and start it will appear. may just have to get cleared, can you not doit yourself, crapy tire could not.
GO to dealer and talk to a tech. Just tell him you unplugged it while doing something and can he clear the code real fast. Give him $20 or $30 bucks and he will. He will also tell you what the code is while he is in there. If you are in So. FL I will do it for you.
4 brand new tire and 4 brand new air sensor .
Car 🚗 need O2 sensor
Calibrate the modular for bigger size tires
Does This sound normal I’m trying to buy this car but that’s what he is telling me
