Centric rotors for '03 STR?
Old Sep 28, 2010 | 07:15 PM
metalmarty's Avatar
Default Centric rotors for '03 STR?
Hello all.
I am in need of some good rotors for my 2003 STR. I don't want any of the cheap nonsense, but at the same time I can't really break the bank at the moment. I know that Centric is a fairly big name in brakes, but has anyone here actually used them? (I'd be especially grateful for feedback on these rotors in an STR.) I found a set of all 4 Centric Premium rotors (correct sizes too, which is uncommon as any other STR drivers undoubtedly know from online searches) for $416 shipped on Rockauto.com. This is roughly half of what I'd expect to pay for Brembos, so if these are any good, I'd like to give them a try.
Thanks in advance,
Old Sep 28, 2010 | 08:24 PM
itspec60's Avatar
I put Centric rotors, rebuilt calibers, and ceramic brake pads on my xk8. fit perfectly and no problems. I also got them from RockAuto...best prices
Old Sep 29, 2010 | 12:19 PM
TheTransporter's Avatar
Just did the brake job not a month ago! I was in the same position as you, didnt want to break the bank on something that probably needed chanign in 12,000 miles or sooner. I Used Centric rotors and akebono pads on all sides. Works perfect! I used Rock auto for the rotors (380 shipped for all 4, Shipping took like 5 days) and got the pads off amazon. Good luck!
Old Sep 29, 2010 | 12:34 PM
tbird6's Avatar
Any chance one of you could post a part number for the STR rotors?? It's very hard to find the correct size rotor.
Thanks!
Old Sep 29, 2010 | 12:57 PM
JagV8's Avatar
Also post whether you have Brembos when posting a part #
(The rotors are a different size Brembo & non-Brembo.)
Old Sep 29, 2010 | 01:50 PM
Staatsof's Avatar
This topic really does get repetitive.
Someone from the Atlanta area just put these on a Brembo equipped STR after getting the wrong ones initially. I think he reported back about 2-3 weeks ago.
I think I've posted 4 or 5 times the Centric listing and there are at least a a couple guys on here who have long term miles on these rotors.
SEARCH!!!
But here: http://www.centricparts.com/index.ph...d=51&Itemid=85
Click on the images to get the specifications
And a cheap price as well http://brakeperformance.com/site/bra...1410&ad=direct
Old Sep 29, 2010 | 02:27 PM
JagV8's Avatar
SEARCH!!!
It does get repetitive BUT most of the data is flawed or wrong. Example: the rear rotors from that first link you posted look to be the wrong size (330mm is 30mm too big) for my 2004 STR (best to call it a 2003 since it was built then and is before the VIN change in 2004).
The second site doesn't appear to give any specs so that would be worrying!
Old Sep 29, 2010 | 03:23 PM
tbird6's Avatar
Thanks for the Centric link but it states they DO NOT sell to the public. So where do you find them?
They do seem to have the correct size front and back rotors for my 2005 STR!
Old Sep 29, 2010 | 04:04 PM
Staatsof's Avatar
Well that is strange. The JTIS I Have shows 365MM front and 330MM rear for the cars with Brembo rotors in 2003.
So I'd have to assume they fit the car he's asking about.
It's not formatted but here's the data:
ItemSpecificationBrake pad material nominal thickness - front - Vehicles with 2.5L, 3.0L or 4.2L engine10.75 mm (0.42 in)Brake pad material minimum thickness - front - Vehicles with 2.5L, 3.0L or 4.2L engine2 mm (0.08 in)Brake pad material nominal thickness - front - Vehicles with Brembo brakes10.30 mm (0.41 in)Brake pad material minimum thickness - front - Vehicles with Brembo brakes2 mm (0.08 in)Brake pad material nominal thickness - rear - Vehicles with 2.5L, 3.0L or 4.2L engine10.95 mm (0.43 in)Brake pad material minimum thickness - rear - Vehicles with 2.5L, 3.0L or 4.2L engine2 mm (0.08 in)Brake pad material nominal thickness - rear - Vehicles with Brembo brakes8.90 mm (0.35 in)Brake pad material minimum thickness - rear - Vehicles with Brembo brakes2 mm (0.08 in)Brake pad material nominal thickness - parking brake pads - Vehicles with Brembo brakes5.50 mm (0.21 in)Brake pad material minimum thickness - parking brake pads - Vehicles with Brembo brakes1 mm (0.04 in)Front brake disc diameter - Vehicles with 2.5L, 3.0L engine fitted with standard suspension components and vehicles with 4.2L engine USA and Canada300 mm (12 in)Front brake disc diameter - Vehicles with 2.5L, 3.0L, 4.2L engine fitted with sport suspension components and vehicles with 4.2L engine Rest of world320 mm (12.8 in)Front brake disc diameter - Vehicles with Brembo brakes365 mm (14.6 in)New front Brake disc nominal thickness - Vehicles with 2.5L, 3.0L or 4.2L engine30 mm (1.2 in)New front brake disc nominal thickness - Vehicles with Brembo brakes32 mm (1.28 in)Worn brake disc discard thickness - Vehicles with 2.5L, 3.0L engine fitted with standard suspension components and vehicles with 4.2L engine USA and Canada28 mm (1.10 in)Worn brake disc discard thickness - Vehicles with 2.5L, 3.0L, 4.2L engine fitted with sport suspension components and vehicles with 4.2L engine Rest of world28.4 mm (1.12 in)Worn front brake disc discard thickness - Vehicles with Brembo brakes30 mm (1.2 in)Rear brake disc diameter - Vehicles with 2.5L, 3.0L or 4.2L engine288 mm (11.52 in)Rear brake disc diameter - Vehicles with Brembo brakes330 mm (13.2 in)New rear brake disc nominal thickness - Vehicles with 2.5L, 3.0L or 4.2L engine20 mm (0.8 in)New rear brake disc nominal thickness - Vehicles with Brembo brakes15 mm (0.6 in)Worn rear brake disc minimum thickness - Vehicles with 2.5L, 3.0L or 4.2L engine18.50 mm (0.73 in)Worn rear brake disc minimum thickness - Vehicles with Brembo brakes13 mm (0.52 in)Maximum front and rear brake disc runout (installed) - Vehicles with 2.5L, 3.0L or 4.2L engine0.076 mm ( 0.003 in)Maximum front brake disc runout (installed) - Vehicles with Brembo brakes0.076 mm ( 0.003 in)Maximum rear brake disc runout (installed) - Vehicles with Brembo brakes0.076 mm ( 0.003 in)Maximum front hub face runout (installed)0.015 mm ( 0.006 in)Maximum rear hub face runout (installed)0.030 mm ( 0.012 in)Front brake caliper piston diameter - twin piston - Vehicles with 2.5L, 3.0L or 4.2L engine38 mm (1.52 in) and 45 mm (1.8 in)Rear brake caliper piston diameter - Vehicles with 2.5L, 3.0L or 4.2L engine43 mm (1.72 in)Front brake caliper piston diameter - twin piston - Vehicles with Brembo brakes38 mm (1.52 in) and 44 mm (1.8 in)Rear brake caliper piston diameter - twin piston - Vehicles with Brembo brakes28 mm (1.12 in) and 30 mm (1.2 in)
Old Sep 29, 2010 | 04:05 PM
Staatsof's Avatar
Did you try the second link?
Old Sep 29, 2010 | 04:08 PM
Staatsof's Avatar
Default Should this be a sticky?
The question gets asked so often so maybe it should be a sticky????
Bob S.
Old Sep 29, 2010 | 04:42 PM
JagV8's Avatar
Oh dear!! The Jag S-Type brochures I posted recently show the Brembo rear as 300mm. I wonder which is right, JTIS or official brochure?
I despair. No wonder this comes up often.
Old Sep 29, 2010 | 04:51 PM
For my 03 STR with Brembo Brakes the parts i used (installed and working right) are:
Front:CENTRIC Part # 12020018 (365mm)
Rear: CENTRIC Part # 12020019 (330mm)
I Checked, it should work with 03-05 STR, 05 SuperV8, and 04-05 XJR
Cheers!
*part numbers are from www.rockauto.com (they list the same as Centric themselves)
Old Sep 29, 2010 | 05:02 PM
Staatsof's Avatar
And since someone asked ... how are they doing and how many miles?
Bob S.
Old Sep 29, 2010 | 05:30 PM
Mafioso's Avatar
I've been eyeballing the Centric BLACK Rotors.. Im curious how long they stay black. That would be sick!
Old Sep 29, 2010 | 06:31 PM
Michael Star's Avatar
Usually the black will wear off from the pad contact, but the rest of it will stay black. Looks better than rust anyday
Old Sep 29, 2010 | 09:08 PM
Mafioso's Avatar
Well when I emailed Centric, they said its black through and through not a coating, Im still spektical as expensive as they are.
Old Sep 29, 2010 | 10:32 PM
Mafioso's Avatar
It wasnt Centric, I dont recall who it was I have thier info at work, and if I can find it on my desk on friday I'll post them up.
Old Sep 30, 2010 | 07:05 PM
metalmarty's Avatar
Thank you all for your replies. I know that several questions are asked about the STR rotors, and I have gained much technical knowledge from the other threads. My purpose in this thread was to compare quality vs price. And it seems as though the centric rotors may be a wise investment based on response.
Also, since this has come up again: the STR does use 330mm diameter rear rotors. The base S-Types use the smaller 300mm out back.
Old Sep 30, 2010 | 07:19 PM
metalmarty's Avatar
These rotors from brakeperformance.com are actually cheaper than rockauto (free shipping vs ~$80 shipping). Does anyone know how they compare withe the centrics? Or the stock brembos for that matter?
And before I get the typical "go search" response, I apologize for not being able to find these answers but it's difficult to sift through so many threads while working 18 hour days. I have searched, but gave up after about two pages of threads. Perhaps my search terms are off.
Thanks again!
SEARCH!!!
