Change Spark Plugs and???
Old Nov 25, 2014 | 04:29 PM
lojo569's Avatar
Default Change Spark Plugs and???
If I am going to change the spark plugs in my 2001 s type 3.0, should I change anything else?.. What is under there.. anti knock sensor or other parts that could/should be changed.. Thank you.
Old Nov 25, 2014 | 06:15 PM
JagV8's Avatar
Coils. Hose which perishes.
Gaskets when refitting.
Old Nov 25, 2014 | 08:10 PM
tony1963's Avatar
Remove the intake and also the plastic injector cassette. It simply unbolts and lifts up, no need to disconnect the fuel line. Remove one bolt from the front of the engine to give the fuel line some slack.
Fit a new crankcase breather elbow when you are there (a rubber 90 degree hose that deteriorates). Also, wipe down the head where the gaskets sit and also both sides of the injector cassette.
Install new upper and lower gaskets.
I also recommend doing valve cover gaskets as well as cam adjustment solenoid seals while you have that intake off.
Replace the O-rings in the IMT valves which are in the intake.
You might as well replace that plastic breather tube that runs between both valve covers to the intake boot, too.
Old Nov 26, 2014 | 09:29 AM
NikolaiDiqnov's Avatar
When I changed the spark plugs, I also replaced the IMT-O rings and the intake manifold gaskets. I did not change the coils. However if you want to be 100% sure replace them also.
Old Nov 28, 2014 | 07:55 AM
tony1963's Avatar
I bought these coils two years ago for my 01 S Type 3.0 and they're still doing just fine.
New Ignition Coil Set of 6 Jaguar s Type 2003 2002 2001 2000 Lincoln LS Pack | eBay
Old Dec 1, 2014 | 04:45 PM
lojo569's Avatar
my car info is in the profile.. you have critized almost every post of mine.. you take this too seriously.. please dont message me again..
dsnyder586
Dec 29, 2024 07:39 PM
cissdm
May 3, 2016 06:02 AM
joesoap
Sep 10, 2015 01:09 AM
MrMellor
Sep 7, 2015 10:22 AM
Bowman
Sep 3, 2015 03:17 PM
