changing out dome lights
Old Feb 28, 2010 | 06:56 PM
cacloss's Avatar
Originally Posted by joycesjag
I used to own something like those back in the day.......but I did not use them to change light bulbs!!
he he he
Old Mar 8, 2010 | 01:46 PM
cacloss's Avatar
Default Rear Map Light update with LEDs
I didn't see any pictures posted for the rear map light change, so here are a few from my update... I hope this helps someone!
There are two little flaps you need to pry open with a small screwdriver to access the #20 torx screws.
Here is a shot of the screws behind the flaps.
The whole unit pulls down so you can access the bulb sockets. Just twist them and the bulbs pull out. Very easy!
Plug the LED into the socket and reassemble.
Here is a comparison shot of the starndard bulb vs the LED. BIG difference! I think this is one of the easiest things you can do to update the look of your car... Enjoy!
Old Apr 7, 2012 | 05:06 PM
zetecstr101's Avatar
i have an 03 str and trying to get the plastic house off for my front dome lights, can someone direct me???
Old Apr 7, 2012 | 08:51 PM
got the new ones in now having a hard time puting the console back in.. smh
Old Apr 8, 2012 | 11:20 AM
got it back but buttons on the map lights r loose.. smh
Old May 2, 2012 | 06:31 PM
rocam81's Avatar
Default LED kits or part numbers
I would like to go blue on the interior lights, footwell and rear dome and door.
Has anyone figured out the proper LED to bulb conversion part numbers?
Ones that fit without having to mod anything?
Also, it appears there is a trick to removing these covers without damaging the darn thing. Any hints there>?
Old May 15, 2012 | 01:52 PM
Jamie McDonald's Avatar
Do you get any kind of error come up on the dash by using LED bulbs. Whether interior bulbs or sidelight bulbs.
Old Jul 9, 2012 | 08:34 PM
  #28
Sponge's Avatar
Thanks to MOMO & Craig for photos and discriptions, made the job of swapping out the filiment lamps for LEDs easy, and whilst I was at it I swapped the little orange downlight for a green one (3mm LED) to match the ones in my door cards.
Unfortunatly after all that work, I decided the white LEDs were too harsh, so I swapped back to the warm, yellowish glow of the old lamps. Hay ho.
Old Mar 26, 2014 | 02:44 PM
Wuzupez's Avatar
I also replaced the dome light and map lights with LEDs. Put it all back together and not one of them work. I must of pulled this thing down 70 times and reinstalled. Not sure what's going on but it does not work. But every other interior light is working fine
Old May 4, 2015 | 03:33 PM
  #30
buck_one32's Avatar
All after market bulbs have to be put in + to -
Old May 5, 2015 | 11:39 AM
  #31
JagV8's Avatar
Non-LED don't care about + and - but by definition LEDs do. (Think what the D means.)
Old May 5, 2015 | 11:44 AM
  #32
buck_one32's Avatar
Yeah. I put LEDs in my cadillac and put everything back together only to find out some came on and others didnt. Had to double-work
Old May 6, 2015 | 12:56 AM
  #33
Warspite's Avatar
Depends on the quality of the LED assembly too. Look at the 194 bulb you took out (in comparison) and you'll see that some of the cheaper LEDs have very little contact area, and have to be placed just right into the socket....maybe more than one time.
Old May 6, 2015 | 12:44 PM
  #34
buck_one32's Avatar
Right. But im orderin led red lights n need to kno how to take the old ones out in the back seat of my s type without breaking nothing
Old May 20, 2015 | 10:48 PM
  #35
Warspite's Avatar
On a 2002, it couldn't be easier. Entire rear housing just pops out (no screws, just small plastic tabs). Gently wiggle it down, using a small fine tipped screwdriver. Assembly separates at the 4 tabs, and you can see which end should be pried...it's got a lift tab. Bulbs will now be accessible. 5 minute job each. The 2 under the dash are 194 also (on order) and are easy to get to. The front map lights will be next. Remember that the single thin wires on the LEDs need to make good contact. Less of an issue with quality ones that are thick like the old bulbs that came out.
Last edited by Warspite; May 20, 2015 at 10:56 PM. Reason: Spell Check is your friend
Old May 21, 2015 | 09:02 AM
  #36
buck_one32's Avatar
I'm not sure if it's the same in the 2000 model. I have one tiny assembly on each side in the rear. The lights under the dash are not covered and easy to get to. I will try to pry the housing off l, but i want to be sure before I separate them from my headliner
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
afterburner1
Dec 16, 2015 12:12 AM
bdboyle
Sep 4, 2015 06:16 AM
King Charles
Sep 3, 2015 12:40 AM
