Changing to Stock Nav
Old Feb 19, 2019 | 12:20 PM
Buttcrackplumber's Avatar
Default Changing to Stock Nav
Hi Guys, Got a 2005 S-Type. Im having a problem with my climate controls. I do not have the stock nav. I have the stock radio. So the climate control unit is separate. I can get my hands on a stock nav unit for about $80. I like the way it looks. I run all my navigation and music through my phone via a wireless bluetooth adapter. So The functionality of the nav unit is not a big deal to me. The touch screen climate controls are. Can I just remove the radio and plug in the factory nav unit? Is there anything else I should be aware of with this swap out? Thanks in advance.
Old Feb 19, 2019 | 01:31 PM
scottjh9's Avatar
The nav, climate, audio and amp use a fiber optic d2b network to interface with the touch screen....i dont know if your car is pre wired with this...if so ,then you might be able to do it...not sure about the modules being the same....i doubt it...plus it would then need to be programmed...that would be the easiest and final step
Old Feb 19, 2019 | 02:29 PM
Datsports's Avatar
Old Feb 20, 2019 | 07:36 AM
M-e-l-l-o-w's Avatar
You will need to modify the wiring.
There is no 'plug and play' wiring connection made by Jaguar, you have to do it yourself or get it made for you.
Mellow
Old Mar 11, 2019 | 02:15 PM
julialaue's Avatar
I have a 2003 S-Type 3L that doesn’t have a touch screen nav console. I dont need the nav so much (although it would be nice) but what i would really like is to have Bluetooth capability to connect to my phone through the console. Anyone know how I can do that? It’s an American Jag. Here is a pic...
2003 S-Type 300L V6
Old Mar 11, 2019 | 02:19 PM
julialaue's Avatar
Hi! What is a wireless Bluetooth adapter and how can i get one? Does it work with your car stereo system? Sorry for the dumb question but this is one thing I am looking for and just bought a 2003 S-Type
Old Mar 11, 2019 | 11:55 PM
Datsports's Avatar
this is what you want . but first check your car is prewired for it . the cable is clipped to the back side of the removable panel behind the audio stack in the boot/trunk .
i bought this one two years ago to find my car although is premium alpine with nav , is not prewired for BT or PHONE .
Old Apr 11, 2019 | 01:26 PM
CactusTom's Avatar
2003 S-Type 300L V6
I just ordered this:
Amazon Amazon
it looked to me like a somewhat easy clean route to hands free BT phone operation with the least visual impact to my stock interior trim. Fingers crossed....
Old Apr 16, 2019 | 06:57 AM
The Jaguar bluetooth system only works with phone calls.
It does not work with text or with music.
In the S-type it is a two part system, the phone control box in the boot linked to the d2b fibre optic system and the bluetooth interface fitted in the centre consul in the car.
You will also need to fit the microphone in the car and a jumper lead into the voice control electrical connector in the boot to make the mic work unless you have the voice control module.
Although the cars are pre-wired for these units there is quite a lot of work involved fitting them.
However you can also fit the later X-type bluetooth interface, UK part number 7W93 10D893 AB, into the s-type. This is a one module unit in the boot, again fitted to the d2b system, with a bluetooth antenna that plugs in to it.
You will still need the microphone and the link in the voice control connector, unless you have the voice module.
This later unit is far better as you can have more than one phone linked to it and it has a singal meter in the display (If you have one.)
It also saves on instalation time and may work on more modern phones, but I am unsure about that last bit?
However as I mentioned even the newer X-type module will only give you bluetooth phone calls, no texts and no music.
Also if you do have the voice control module that will probably need to be re-programed using the Jaguar SDD software to activate the phone voice commands. (But it may not!)
Mellow
Maximillion
May 12, 2017 05:05 AM
jagxkrtoofast
Jun 11, 2016 08:30 PM
bfsgross
Sep 27, 2012 12:47 PM
stefan063
Jul 3, 2008 10:54 AM
Grim001
Apr 4, 2008 10:54 PM
