Check Engine Light on!!!???
Old Jan 6, 2008 | 05:48 PM
FactoryJaguarTech's Avatar
Default RE: Check Engine Light on!!!???
it is bolted to the front of the throttle body. That code normally means replacing it. It is a roundish looking valve with a small electrical connector going to it. Sorry I can't be more descript than that. But it is on very front of throttle housing area close to intake manifold
Old Jan 10, 2008 | 11:41 AM
EDLFWood's Avatar
Is that the Air Mass Meter? Do they make an after-market perfomance version?
Old Jan 10, 2008 | 01:12 PM
Dennis's Avatar
ud
Does the engine Idle rough?
Old Jan 10, 2008 | 07:41 PM
It is not the mass air meter. it is a roundish valve. Hard to explain. I will try upload picture of it.
Old Jan 11, 2008 | 10:22 PM
Sultan's Avatar
I had the same problem, the check engine sign turned on. So I took it to the dealer and it ended up being a hold fuel filter, I wasn't told I was supposed to change it every 30,000 miles even if I was I only put 5,000 miles on the car since I got it. But long story short warrenty didnt want to cover it and i was left with a 600 bill to fully clean the system.
BrentGardner
29
Dec 16, 2024 12:13 AM
big d
Sep 3, 2015 07:37 PM
niner nellie
Sep 1, 2015 10:53 PM
tony bosco
Sep 1, 2015 02:06 PM
daro31
Aug 27, 2015 09:26 AM
