Cicking noise coming from Engine
Old Jan 20, 2010 | 02:06 AM
ndy4eva's Avatar
Question Cicking noise coming from Engine
When I do a cold-start (in the morning or parked for while), I hear the clicking noise around the fan belts. It goes away after a short drive. I think some bearing or wheels require some lubricant, but it’s real hard to determine which.
Also, when I accelerate (1-2 gear, up-hill), I hear some knocking noise from the engine. This also seems to go away after the warm-up.
Any ideas?
Old Jan 25, 2010 | 02:02 AM
ndy4eva's Avatar
anyone!?
Old Jan 25, 2010 | 02:49 AM
JagV8's Avatar
Statement of the obvious: it could be any of the things the drive belt passes over.
Perhaps #1 suspect would be the tensioner.
I think I heard a pro would spray something (harmless!) on it to see how the note changed or some such but don't mess without finding whether that's so and what is safe to spray. (OK, a pro might KNOW what it would be.)
Have you checked the drive belt isn't frayed or breaking up?
Have you checked its tension mark?
Maybe this is a job to take to a shop tech.
Old Jan 25, 2010 | 06:01 AM
Enthusiast's Avatar
Check your oil level. Could be valve clatter because of low oil level.
Old Jan 25, 2010 | 07:18 AM
Jon89's Avatar
A mechanic's stethoscope is the best tool for finding these pesky engine bay noises. About $20 at your chain auto parts stores if you can't borrow one from somebody. Yep, check your oil level, your belt, and then use the stethoscope to start listening to the components that the belt drives. Start with the tensioner, then move to the water pump, and so on down the line. Watch out for that spinning fan blade....
Old Jan 25, 2010 | 11:50 PM
ndy4eva's Avatar
Thanks for the inputs... I will check out the tensioner first and find that spray
The oil is good as I topped it after replacing IMT O-rings.
BrentGardner
29
Dec 16, 2024 12:13 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
niner nellie
Sep 1, 2015 10:53 PM
lee,lee
Aug 31, 2015 04:35 PM
Sshenton1975
Aug 30, 2015 09:29 AM
