Cig lighter & power outlet not working
Old Nov 14, 2010 | 08:29 AM
Michael Star's Avatar
Default Cig lighter & power outlet not working
I've checked all the fuses, but I don't seem to have power to either. Is there something I am missing?
Old Nov 14, 2010 | 08:48 AM
Enthusiast's Avatar
Mine just went down too............
Old Nov 14, 2010 | 01:31 PM
RizwanSharp's Avatar
Double Check the Lighter Fuses from the following document:
http://www.ownerinfo.jaguar.com/extf...0emergency.pdf
Thanks,
Rizwan
Old Nov 15, 2010 | 05:30 AM
wiafs02's Avatar
check the fuse, it happened to mine twice this year and i only had to replace a fuse
Old Nov 15, 2010 | 07:42 AM
I replaced the fuse even though it looked good and now it works. Just and FYI to anyone else that might have the same issue. It is #32 on the passenger side kick panel.
Old May 28, 2017 | 05:45 PM
Gabegriesinger92's Avatar
Mine did the same, I replaced the fuse and still nothing
Old May 18, 2019 | 11:58 AM
Vandyone's Avatar
Default Mine too
Did you ever find out what was wrong with the cigar lighter?
Old May 18, 2019 | 05:16 PM
Warspite's Avatar
Old thread, but common problem.
On 1st generation X-200 models, it is fuse 32 in the passenger kick panel. Should be 20 amp fuse. I found a blown 10 amp in mine, and replaced it with the proper rating.
The contact within the lighter assembly is small, and if the lighter was actually used to light cigars or cigarettes, would accumulate ash and make the assembly inoperative. Spray the receptacle with electrical contact cleaner and wipe out the residue.
Combination of both actions did the trick.
Old May 19, 2019 | 01:53 PM
Vandyone's Avatar
Default Thanks for the info
Turns out it was f58 in the boot 4 fuses to check relay i only expected one fuse and relay to check but now i know.
allenman85
May 10, 2021 03:11 PM
Chet Ramnarain (bozzner)
Sep 3, 2015 07:47 PM
Sep 3, 2015 12:21 PM
XFR_Gold
Sep 2, 2015 12:24 PM
XJsc-guy
Sep 2, 2015 11:43 AM
