Cold Weather caused two issues.
Old Jan 23, 2013 | 08:31 PM
Stype student's Avatar
Default Cold Weather caused two issues.
First, my battery was drained in the cold weather and I needed a boost to get her going.
When I tried to turn her over the dash needles moved a bit, and the rmp needle went up to above the 8000 rpm and stopped there (the engine never turned over so no revolutions even happened). I boosted the car and it started fine and idled like it does, but the needle stayed up above the 8000 rpm.
So, is there a way for me to reset the needle to get it back to zero?
Second, the weather has been so so cold (-26 with a windchill of -38) and my passenger rear door will not engage with the body to close. I assume that the grease in the door has solidified and has stopped the mechanism from engaging. I am wondering if there is a way for me to loosen that up safely or a way for me to re-engage the latch so it will work?
thanks a lot everyone,
I appreciate the help
Philip
Old Jan 23, 2013 | 08:58 PM
Mikey's Avatar
No idea about the tachometer, but the door is just plain frozen. Try a hair drier on the mechanism.
BTW- you know that a windchill factor is not relevant to inanimate objects, right?
Old Jan 23, 2013 | 09:23 PM
Bad Cattitude's Avatar
Thaw it out in a garage
Old Jan 24, 2013 | 02:32 AM
JagV8's Avatar
Tacho maybe just needs to get good and warm.
On the later cars there's a reset for the gauges but doesn't work the same on the 1999-2002 cars. (I suspect there IS one, we just don't know it I think. The "trick" is to get it into diagnostic (ETM) - google for Ford HEC and Ford cluster test mode and the like if you fancy a go.)
Old Jan 24, 2013 | 07:13 AM
Jayt2's Avatar
Veteran: Navy
Active Streak: 30 Days
How old is your battery, if it's 3-4 years old, it may need replacing. Sounds as though it's on it's way out..
Old Jan 24, 2013 | 10:51 AM
abonano's Avatar
+1 on battery
SD96XJ6L
Jan 12, 2022 04:30 AM
42Ajd
Dec 30, 2015 09:45 AM
duecedriver
Dec 25, 2015 11:47 AM
42Ajd
Sep 21, 2015 07:37 PM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
