fuel pump circuit
Old Jan 24, 2013 | 01:09 AM
ursusarticus's Avatar
Default fuel pump circuit
I have a 2000 S-type that rode home on the back of a carrier after the fuel pump stopped. what is in the "control circuit" that would not allow the pump to run? It ran fine then it was parked for a few minutes and then it would not run, it started but would not idle. This is my mom's pride and joy and I pay my rent for the privledge of living in her converted garage apartment in the back yard in exchange for keeping her vehicles running. Thirty years ago I knew how Bosch "L" fuel injection worked, but I have not had to work on a system for twenty years and over Thanksgiving I had a minor stroke that affected some of my memory so things that are in the long term memory are hard to retrieve. I want to get the beast to run so that she can drive it short distances. I am thinking a relay or fuse or something like that. It would start but not idle, I just need to know where to start to make the fuel pump run to build the pressure to keep it running.
Old Jan 24, 2013 | 02:41 AM
JagV8's Avatar
For sure check fuses & relays, but pumps do sometimes fail.
Search on here will get you all the details of replacing one if you need to do so.
Grab JTIS to make your life MUCH easier.
Old Jan 24, 2013 | 10:56 AM
abonano's Avatar
To add to JagV8 - Definitely sounds like a failed fuel pump - I would test the fuel pressure at the rail - cold engine with key to start (but don't crank the engine) - fuel pressure should be at least 40 psi or higher.
You can also check the inertia switch driver's side under dash - but if that was tripped (red button) you would get a "no start" condition.
Another area to look at - the fuel filter - when was it last changed? The fuel filter is something many owners forget about and not change... Good Luck..
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
ccfulton
Sep 20, 2015 05:15 PM
Kmw
Sep 8, 2015 04:52 PM
Sprayall
Sep 3, 2015 07:49 PM
