Colder Thermostat:
Who sells a colder thermostat for the 07/08 STR? I guess it's different than the 03/06. Eurotoys sells them for 03/06 but say 07/08 are different design...
Not necessarily looking for increase in performance, just not happy with where the car runs with OEM t-stat. But cooler is always better in summer months which is the only time I drive the car.
The only time a car overheats WRT coolant is if the system pukes water. The hotter the motor , the more power it produces.
Where you will find big gains is decreasing the air/fuel intake charge temp , the lower you can get this , the more fuel you can add and thus make more power.
So the rule is motor hot , intake charge chilled...
I believe that's about what Jag designed the engine to run at.
Also interesting---my Service Manual says the t/stat for the SC engine begins opening at
84C(183F)and should be fully open at 98C(208F).
For the NA 4.2 t/stat begins opening at 86C-92C(190F-198F) and fully open at 102C(216F).
Thermostats open at the degree that is specified on the type, so a 165* thermostat will open at 165* and a 180* thermostat will open at 180*. Therefore this does nothing for performance but let the thermostat open earlier but does not sustain that temperature while operating (I don't know how it could?).
If you want cooler temps and more performance, experiment with a high flow intercoolers pump instead. Search my thread from about a month ago on the topic. I haven't installed mine yet but others have with good luck.
No idea why someone would want to do that............
A 80*C thermostat is supposed to be fully open at 92*C given the 12*C differential between closed and fully open in standard designs.
Reported results using a 80*C thermostat in Jaguar 4.0L SC engines are that in stop and go driving the engine hovers at 195*F and a few degrees lower for highway cruising.
The ecu turns the fans on a 196*F and turns them off at 191*F. That hysteresis avoids constantly cycling the fan.
That being the case, staying just below 196*F avoids running the fan all the time.
The ecu still goes into closed loop because that transition is made at approximately 170*F.
The cooler temps are also make life easier on the hoses ... especially after turning the key off after a good run.
Who says so? Gates ... the hose manufacturer.
It also lessens the severity of dexcool gel. When dexcool is overheated it's precipitates form a gel. The overheating happens at hot spots where the coolant is superheated and vaporises.
As a matter of fact, most of the plastic materials under the hood ought to be a bit happier.
BTW, from the Jaguar engine course manual as opposed to any other source, the following passage appears in the technical theory portion:
Notice that the anticipated operational range of the thermostat fully includes a 80 *C thermostat in that statement.
And no, the sky isn't going to fall down if the operating temperature is lowered those few degrees.
In fact, if the statement from the manual is parsed correctly, using a 80 *C thermostat still falls within the published parameters.
On both systems, the thermostat starts at open at 80-84 *C (176-183 *F) and is fully open at 96 *C (205 *F).
It's neither negative nor positive. It's a bunch of info that doesn't directly apply to the type R.
There are no known issues with the cooling system hoses on S-types so an effort to lower the coolant temps will be an attempt to fix something that's not broken.
There are also no known issues with coolant turning to gel on these cars.
Some people like to predict that the sky is always on the verge of falling.
That's a blatant falsehood.
1) the numbers apply equally to a type R as to a XJR
2) the Jaguar engine manual applies to all models ... including the type R
3) rubber is rubber and Gates did not issue a special exemption for Jaguar in their document
4) dexcool is dexcool and Jaguar does not escape the laws of physics or chemistry
In general, general knowledge applies to all vehicles ... Jaguar is not a special little world where known behaviour is suddenly suspended.
However, if someone has no experience with the supercharged variant, nor an interest in improvements, it would be best if they stood aside.
To certain degree yes. But bad advice is bad advice. Do your cooling fans run contentiously?
pdowning6
May 21, 2010 03:18 PM
