Coolant hose under the supercharger
Old Nov 30, 2014 | 09:04 AM
gkt33's Avatar
Default Coolant hose under the supercharger
Howdy, I have a 05 s type r. I'm in the process of completing the dreaded coolant hose under the supercharger. I can't remember where the small end of the hose connects. Is it the TB and if so does it matter which port? I don't have a manual nor access to TIS. Any help would be greatly appreciated! US spec left hand drive version
Old Nov 30, 2014 | 09:18 AM
Gary,
I've moved your question from General Tech Help to S-Type forum. This is the place for tech questions about your model.
Old Nov 30, 2014 | 09:28 AM
Is this the JTIS STR cooling hose connection diagram you need?
Old Nov 30, 2014 | 12:04 PM
gkt33's Avatar
Appreciate the response, I've looked at that one but doesn't appear to be the one. There are two ports on the TB and two coming from the EGR valve. The coolant hose comes out from under the SC and up, and I can't remember where that end connects to.
Old Nov 30, 2014 | 12:09 PM
Try here https://www.jaguarforums.com/forum/s...-hoses-102914/
Old Nov 30, 2014 | 12:34 PM
2004STR's Avatar
Hey everyone,
Just joined. I'll do my intro later today.
I know on the 2004 the hose under the supercharger goes to the top fitting on the throttle body. The short hose from the egr goes to the lower fitting.
Hope that helps.
Mike
gkt33's Avatar
https://www.jaguarforums.com/forum/a...dy-diagram.jpg
That's the one, my problem is which port on the TB does it connect to?
Old Nov 30, 2014 | 04:54 PM
David_h's Avatar
I recently had the same question and ended fitting it to the upper fitting on the TB. It seems to fit well as the lower fitting on the TB does go to the EGR and it looks correct.
Old Nov 30, 2014 | 07:50 PM
gkt33's Avatar
Thanks all, I will give it a try in the am.
Old Dec 5, 2014 | 02:31 AM
From JTIS removal/refitting procedure:
Is this the one you need showing the hoses?
Old Dec 6, 2014 | 02:26 PM
gkt33's Avatar
Attachment 101945
Yes Sir, That is the one!!
silkcat
Jan 18, 2025 04:29 AM
mrplow58
Jan 21, 2024 05:53 AM
Wahooesprit
Dec 23, 2019 02:01 PM
duecedriver
Dec 25, 2015 11:47 AM
Lannyl81
Sep 19, 2015 08:07 PM
