coolant losses Jaguar S type 2005
Old May 29, 2018 | 07:15 AM
Ben02's Avatar
Default coolant loss Jaguar S type 2005
hello
Frequent loss of coolant, Jaguar S type 2005
A Jaguar dealer told me it was a blown up Head Gasket.
i decided to use a head gasket repair sealant. but after a week or so the coolant started going low again. Through all these times, i
have always been able to use the car even for longer distances eg. Netherlands - Poland (about 14 hours drive) and back, without any issue
of overheating for almost 2 years, I don't see any white smoke from the exhaust, no milky substances of the coolant.
Recently i have constantly seen leakages of coolant around the engine and i keep adding coolant to keep the level.
I feel it's not actually the head gasket because the coolant is not been consumed by the engine.
with new cap for the overflow tank, still the same.
Now, i can't use the car for longer distances because anytime i go beyond 120-140 km/h, the coolant overflows through the cap
leading the engine to overheat, and the car to "Restricted Performance".
Any advice?
Old May 29, 2018 | 08:33 AM
NBCat's Avatar
After a cold soak, preferably overnight, pressurise the cooling system to 1 bar and check for leaks. It is not a good idea to use products that offer to 'seal' leaks as they often end up blocking the radiator and heater core.
Is the vehicle fitted with a 3.0 litre or 4.2 litre motor?
Old May 29, 2018 | 09:26 AM
Ben02's Avatar
I am not too sure but it is 2005 2.5L V6
Old May 29, 2018 | 10:44 AM
NBCat's Avatar
The diagnostic procedure in post no. 2 includes the 2.5 litre as well.
Old May 29, 2018 | 11:41 AM
Ben02's Avatar
NBCat, which post no.2 are you talking about?
Any ideas best way to deep clean the radiator/heater core?
Old May 29, 2018 | 07:21 PM
aholbro1's Avatar
I'm pretty sure NBCat is referring to this one: https://www.jaguarforums.com/forum/s...4/#post1903608
Cheers!
Old May 30, 2018 | 12:32 PM
NBCat's Avatar
The same diagnostic procedure applies to all engines fitted to the X200 and X202.
The radiator and heater core should be drained and backflushed to remove any residue left from the sealer. The cooling tubes of modern radiators are actually quite small and can become easily blocked by products claiming to 'seal' leaks.
Follow the procedure in the Workshop Manual, which you can download here:
http://www.jagrepair.com/images/Auto...M-Workshop.pdf
Old May 31, 2018 | 04:45 AM
Ben02's Avatar
Thanks. i will try those
Old Dec 28, 2018 | 06:59 AM
Ben02's Avatar
I think I have found where the leak is coming from. Now it has really become really serious because I can actually see it dripping off under the water pump. I also see some water inside the water pomp area but the leaking is actually coming from under. Now I fill up the tank and within minutes is gone.(1 does it mean there is problem with the water pump? I am thinking of taking it to the specialist. Wanted to see if there's any idea from the community
Old Dec 28, 2018 | 09:19 AM
NBCat's Avatar
It's entirely possible the water pump seal has failed. Did you pressure-test the cooling system when you first noticed the drop in coolant level?
May be best to take the vehicle to the specialist shop for diagnosis and repair.
Old Dec 28, 2018 | 02:22 PM
Ben02's Avatar
ok. I did but sometimes it just becomes stable with no leak for about 2 weeks or more so I found nothing. think will go to the specialist. thnx.
Harry Peter Rose
Feb 13, 2018 08:14 PM
wa3ra
Jan 9, 2018 12:24 PM
fauxoscar
Sep 1, 2014 09:02 AM
Jerry123
Jul 6, 2014 11:13 PM
Sevren
Jan 23, 2009 06:44 AM
