Cooling Fan high speed inop, many new parts installed
With the A/C on max at normal pop temp I notice the cooling fans on low speed. Does the new updated cooling fan assembly only run at 1 speed?
I believe the fan issue is why I'm having A/C issues at a stop, if its not either way I need to take care of this first.
I had a radiator leak so I replaced the rad. I then noticed the cooling fan not running so I replaced the Fan + cooling fan control module which was 1 unit. While I was in the area I changed the thermostat housing and some other unrelated items. All of the above are dealer items.
The engine runs cool with no over heating issues but I have yet to see the fans run at full speed. Freon pressure's seems to be ok, A/C blows cold when the vehicle is moving but warms up at a stop.
Chercarson (10-06-2019)
From what I understand the cooling fan control module and fan motor is 1 unit. I paid $540 from my local dealer.
