Cost to repair evap leak
Old Nov 2, 2018 | 08:07 AM
miller1211's Avatar
Default Cost to repair evap leak
mechanic says I have an evap leak between cylinder, head & block - between intake. What's the cost to repair?
Old Nov 2, 2018 | 08:44 AM
NBCat's Avatar
Please provide vehicle details.
The evaporator is part of the air conditioning system and is inside the vehicle. Perhaps you should list conditions and symptoms the vehicle is displaying.
Old Nov 2, 2018 | 08:54 AM
miller1211's Avatar
Hi NBCat,
According to the mechanic - it's leaking air between the cylinder, head and block - between the intake. The only thing I've noticed is the loud hissing noise while driving. Then it stops. I really haven't noticed anything else. I'm just afraid of driving it thinking it will cause more problems or stop on me.
Old Nov 2, 2018 | 09:15 AM
NBCat's Avatar
What is the MY, engine size and miles?
Old Nov 2, 2018 | 09:45 AM
miller1211's Avatar
5.0L w/out supercharge. I just purchased an engine in May 2018 (previous engine had warped heads and block due to coolant). Used engine purchased from 2011 XJ 44,500 miles. I've added about 2500 to that, so the miles on this engine is about 47K miles.
Old Nov 2, 2018 | 10:14 AM
NBCat's Avatar
Respectfully, you still didn't provide the type of vehicle you're wanting help with. The 5.0 litre unit was not fitted to the X200 or X202.
Here is a thread regarding repair to an overheated 5.0 litre engine:
https://www.jaguarforums.com/forum/x...warped-198197/
Old Nov 12, 2018 | 08:20 AM
Jagmister's Avatar
My car had the same symptoms as yours is having. I went to one crook mechanic, who told me it was also my evaporator as well..turned out, I needed to flush the a/c system and charge it again, Problem solved! Paid about $75.00.
Old Nov 12, 2018 | 09:20 AM
JagV8's Avatar
So... wrong forum... maybe a chance to find out which car & thus which forum?
Old Nov 13, 2018 | 08:26 AM
Brutal's Avatar
Evaporator= ac system
evaporative system= fuel system vapor control
leak between cylinder head and intake=vacuum leak
educated guess $100- $1500
non educated guess $50
JamesT81!
May 24, 2017 06:30 AM
flatlander
Mar 20, 2017 10:18 AM
Cliff5.0SC
Nov 2, 2016 05:25 PM
zerovette
59
Jun 23, 2013 05:42 AM
christer200
Apr 8, 2009 03:05 PM
