Could this be a gear shifter cable problem?
Old Sep 13, 2013 | 04:59 PM
daboss085's Avatar
Default Could this be a gear shifter cable problem?
Shifter sometimes is a bit stuff from shifting from Park to either Reverse or Drive. Other times its loose. Car also "Jumps" sometimes when shifting into Reverse. And I will also get a squeal noise when I put the car into drive sometimes, usually on a cold start. The car shifts fine on driving, its mostly a idle thing. Thanks.
Old Sep 13, 2013 | 05:15 PM
tbird6's Avatar
Only one way to know. Adjust the cable and see if that fixes it. If the cable can't be adjusted then it's most likely stretched and should be replaced.
Have you actually crawled under your car to have a look?
Did you check the cable mounting bolts on the transmission?
Old Sep 13, 2013 | 08:24 PM
motorcarman's Avatar
Jaguar issued a revised selector lever cable so you might need to upgrade.
Here is some reading material.
bob gauff
File Type: pdf
mbergen
Oct 23, 2019 10:26 PM
Gus
Oct 15, 2019 12:29 PM
Rlover
Mar 30, 2016 10:04 PM
user 652867429824
Oct 28, 2015 10:18 AM
lordpeterk
Sep 6, 2015 01:50 PM
