Cranks and dies immediately
Old Apr 20, 2020 | 01:16 PM
turkay's Avatar
Question Cranks and dies immediately
Hello,
I've recently bought a Jaguar S Type R Supercharged V8 4.2l from 2004 (December), the car was running when I bought it, had the famous restricted performance though. The owner said it had a issue at the Oxygen Sensor (which he changed but I doubt it) and it had a P1339 code issue which he said he kept clearing with the OBD but kept coming back up. Anyone faced this issue before? I tried changing batteries (Removed the old one, put the once I have in my S Type 3.0l which is a 100AH 860A. But to no avail, same issue.
Many thanks.
Old Apr 20, 2020 | 01:20 PM
NBCat's Avatar
Connect to the PCM via the OBD port using a Bluetooth interface and smart phone with the Torque app to read the fuel pressure. With the ignition ON the fuel pressure should be around 3 bar (300 kPa) prior to engaging the starter.
Old Apr 20, 2020 | 01:27 PM
turkay's Avatar
Gonna try and find a OBD Scanner, to connect it. Can't even get the car moving because it's not yet registered (fellsbad). Once I manage to do that I will keep you up to date! Thanks!
Old Apr 20, 2020 | 01:32 PM
NBCat's Avatar
If there is no fuel pressure when you perform the test, check the fuse and power to the pumps. The main pump is on the RH side.
Another possibility is the CPK, which sends a message to the PCM indicating that the crankshaft is turning. If the CPK fails, the PCM shuts off power to the fuel pumps.
Old Apr 20, 2020 | 01:40 PM
JagV8's Avatar
Endlessly clearing a code is not a fix. You can look up its meaning and the list of possible causes... free download
Old Apr 24, 2020 | 07:25 AM
turkay's Avatar
I feel like a complete moron, turns out the car had no fuel (Fuel gauge was showing that it had half, but in reality nada 0) so I went and bought 98 Octane fuel put some in the fuel reservoir, it sparked like a Spitfire in the 2nd WW, error is still there but thank god it was just the fuel, I bought the car recently so yeah, I am trying to figure her out and see what ails her, but once I get her registered I will take her to the dealer and figure the lass out.
Cheers lads!
P.S: The previous owner told me it had half a fuel tank (Yeah thanks for that lie buddy) so hence why I did not bother checking if it had any fuel, but after trying to crank her a bit more, I came to the conclusion that the gauge might be faulty and I should try 5l of Petrol in the tank. Will keep you up to date once I take her to the dealer to fix the errors after I registre my missus!
Old Apr 24, 2020 | 02:33 PM
scottjh9's Avatar
you would be surprised how many of us have had the no gas no start scenerio on many different things from lawnmowers to cars...don't feel bad....my latest was my boat....been sitting for 10 months and the gauge was showing half....it even primed and tried to start....5 gallons gas and purrs like a kitten....glad you got it going
cemmixer1
Jun 14, 2018 04:46 PM
fred2fred
Aug 6, 2017 08:48 PM
MarcisW
Jul 19, 2014 12:01 AM
kert1224
Jan 17, 2014 02:41 PM
Raheny
Dec 2, 2009 07:10 PM
