cylinder 6 misfire?
Old Aug 5, 2011 | 06:21 AM
Mountain s type's Avatar
Default cylinder 6 misfire?
hey guys,
im stumped again. i have a 2001 s type, i have recently changed the spark plugs valve cover gaskets and spark tube seats and i still have a recurring cylinder 6 misfire code. i dont know the best place to look next. i have a code reader i could pull ffs if i knew what might be the important number to look at. any ideas?
Old Aug 5, 2011 | 06:26 AM
joycesjag's Avatar
Mst,
You should post this in the "S Type" Section here. Maybe one of the mods will move it for you.
As far as the misfire, post up all codes pulled. Did you replace the #6 coil??
Also help us to help you, put your year, engine size in your signature, model.
Old Aug 11, 2011 | 04:23 AM
yes i replaced the coil packs when i did the seals.
Old Aug 11, 2011 | 04:25 AM
2001 s type 4.0 whith the traction control and sport package, automatic.
Old Aug 11, 2011 | 04:36 AM
JagV8's Avatar
Just checking but which one do you think #6 is?
On your era car, it's bank 2 aka left, #2:
fan
5 1
6 2
7 3
8 4
Later cars are different.
Also worth checking #5 and #7 as the PCM isn't perfect.
Old Aug 11, 2011 | 12:40 PM
tbird6's Avatar
Swap the coils around. It's not common but there have been reports of brand new coils misfiring. Also are you running any goofy plugs like split fire ?? Do not use them. Use the factory recommended plugs. You will gain nothing with those snake oil fancy plugs.
Recheck that number 6 is still dry too.
Old Aug 13, 2011 | 02:21 AM
running champion iridium plugs . I did the whole drivers side coil packs and spark plugs when i changed the spark tube seals three other cylinders also read error codes after spark tubes. all cleared up with the exeption of six, which was the one that read an error code before spark tube seats finally failed. i had thought it was related but six refuses to work right.
Old Aug 13, 2011 | 03:27 AM
JagV8's Avatar
Are those the right plugs?
If they are, back to basics. Compression. Cats. Any air leaks (check fuel trims). Wiring. PCM itself - getting wet? Etc.
Worth checking the freeze frame data, too.
aode06
Jul 28, 2023 02:26 PM
pnwrs2000
Nov 17, 2015 04:04 AM
Delta66
Oct 4, 2015 05:40 PM
reb1999
Sep 26, 2015 08:41 AM
